Clarity Cap ESA Capacitors
VR3
I am thinking changing out the woofer network on my towers to the ESA ---
Would I notice a big difference? I was thinking of throwing in a 12 uF MR on the part of the network that goes inductor, cap, resistor as I think may make a big difference?
I think I could justify dropping a MR series in the network somewhere that would make the biggest difference?
What do you guys think?
In transparency, no. But, with ESA's or MR's you will have tighter bass."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
FYI, "IF" you ever decide you're done, use liberal amounts of hot glue on everything. On my custom black towers, the tweeter/mid crossovers have about 3-4 sticks on each one.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Hmmm - I dont think I feel the need for tighter bass, not with these Excel drivers anyway - something to ponder. Maybe I wont upgrade that network any further..
Hmmmm - ponder ponder ponder- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
