How should I do this???
amulford
amulford Posts: 5,020
edited January 2004 in 2 Channel Audio
OK. I have a receiver set up in one room. This receiver has a 2nd zone feature on which I have set up some SDA 2B's that I use for 2 channel. The only problem is by usung the 2nd zone for those speakers, it ties up my speaker level outputs for 7.1.
I want to expand the HT set up to 7.1. Now I already plan to drive the 2B's with a seperate amp using the pre outs on the receiver. That's not the problem.
The 2nd zone has no tonal adjustment. I have an old equalizer, but I don't know if the SDA's are very receptive to them. I don't really want to set up another pre amp.
Any Ideas????:confused:
Post edited by amulford on
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2004
    If you really feel the some tone control is needed, there is no reason you can't put an EQ between your Zone 2 pre-outs and a 2 ch amp.
    It's possible to even find some EQ's that are remote controlled.
    More later,
    Tour...
    Vox Copuli
  • amulford
    edited January 2004
    Tour,
    Thank you.
    Do you think the speakers would have a problem with this?
    anthony
  • Tour2ma
    edited January 2004
    No problem with any kind of reasonable EQ application. That said, EQ can be overdone leading to clipping and other ills...
    More later,
    Tour...
    Vox Copuli
