Sunfire Theater Grand Processor static in front right channel. What can it be?
newrival
newrival Posts: 2,017
edited December 2010 in Electronics
Hey guys.
I hope someone can give me some direction here. My Sunfire pre/pro developed static in the right front channel. The signal is still there, just with static. I tried rca and xlr inputs but its there on both. switched through all the dsp's and settings, still there. So I'm thinking it might be the ouput? i don't know.
What can I check? I can take the cover off and snap some pics if that's helpful.
Post edited by newrival on
    treitz3 Posts: 19,953
    Hello newrival, are you 100% sure it's that and not a connection, speaker, crossover or source issue? May want to eliminate other possible suspects before you go diving into something that may not have an issue.
  • newrival
    sunfire did offer to help... for $475 plus $150 shipping. They said regardless of diagnosis, they would only replace the board and ship it back, even if something just needed to be cleaned.
  • newrival
    treitz3 wrote: »
    I'm 99.9% sure. I've tried different speakers and still got static. Used a different wall outlet, different inputs, same problem.
    Have you swapped L & R inputs going from the source?
  • newrival
    ummmm, i dont think i've tried that. but i did try different sources
    Well, if different sources didn't change anything then it seems that you have diagnosed which component correctly. Have you tried Deoxit on all external connections and the volume pot yet? Also, the speaker cable connections may have been compromised.
  • newrival
    thanks. I'll look into that tonight. I'll get some deoxit and get the cover off and see if there is anything to see :)
    You are welcome. Please make sure that the unit is unplugged and all Deoxit is dry before plugging back in. It sounds like a connection gone bad somewhere and "usually" it is a relatively simple fix. Keep us posted on the results and have a good evening.
    tonyb Posts: 33,068
    Good advice from Tom but if it doesn't work, and you've been a good boy this year, just maybe Santa will show up with something for you.
  • wayne3burk
    wayne3burk Posts: 939
    did you switch the output of the right front to the left channel of your power amp??? i.e. reversing left and right inputs on the front channel inputs of the power amp to see if the static moved to the left front speaker.
    That would isolate whether it's the pre/pro or the power amp connecxtion.
    -- swaptronics is our friend --
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • newrival
    tonyb wrote: »
    I'm hoping Tom's advice on the Deoxit will help. I pulled the cover off and quickly realized that I'm not going to be of much use in there with all the integrated circuits and surface mounted processors. It all looks really clean and i checked out the alignment of the connections to make sure theres no chance for it to be open, and it all looked ok. I'm going to track down some deoxit and squirt it in there and hope for the best! Beyond that, I'm afraid Santa may be out of funds for the winter. But who knows, I have been awfully good :biggrin: hehehe
  • newrival
    I haven't found deoxit yet. However I have done some more experiments to find out at which stage the static is occurring. T Initially I thought it was happening at the output since it was showing up through every input. his seemed to be confirmed due to wiggling the output cables and being able to cause some louder static. However, this turned out to be an anomaly and has been unreproducible. I got to thinking about how the the Holography DSP and how it works much like SDA in that it sends a portion of one channel to its pair on either side and vice versa. I turned it on holography and low and behold, a faint static in the left channel where there wasnt before. This tells me that it's not the output and is somewhere between input and DSP. I imagine there are a few stages in between with these processors, but at least I feel like I've narrowed it down a little bit.
    Given this info, are there any new recommendations? How should I apply the Deoxit? Should I just spray the whole board down? replace fuses? Any help is appreciated.
  • TNRabbit
    TNRabbit Posts: 2,168
    Deoxit should really only be sprayed inside any pots, sparingly.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • newrival
    ok. so deoxit isnt going to solve his problem then... any suggestions? anyone? pleeeeease?
    sorry i hate to beg, i just love this pre/pro
