Please suggest amp for RTi12's
    edited December 2010
    Yakapo wrote: »
    If you had to choose between a B&K AV5000 -5 channel (series 1) and a B&K reference 2220- 2 channel, which would you suggest? If I purchased the AV5000 I would biamp the RTi12's.
    If I had to choose, I would take the 2220. Forget about bi-amping, and replace the jumpers with good quality wire.
