db 10 subwoofer
Systems
Systems Posts: 14,873
edited January 2004 in Car Audio & Electronics
Hi, i have a polk audio db10 subwoofer and i lost the specifications sheet. does anyone have it or can point me where to find it? thx..
Testing
Testing
Testing
  • slim
    slim Posts: 69
    edited January 2004
  • Jstas
    Jstas Posts: 14,985
    edited January 2004
    Um, dude, there is alot more history to Polk Audio than just the past 3 years.
    dB10's came before the DX10's.
    Expert Moron Extraordinaire
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2004
    rated at ...
    either 4 or 8 ohms depending on your sub - single voice coil
    300 w rms (will probably take more like 400ish or better though if you do a nice solid install and use a quality amp and wiring).
    0.66 cubic foot box reccomended - sealed.
    sensitivity was like 83 or 84 db's
    frequency respnse in that 20 to 300-ish range
    and the cutout hole is 23.6 cm / 9.3 inches
    The Artist formerly known as PoweredByDodge
