Ei 6CA7/EL34 - Fat Bottle ?
heiney9
heiney9 Posts: 25,445
edited December 2010 in 2 Channel Audio
Just a quick question for those that have used the Ei 6CA7/EL34 fat bottle. Is it as large a round as a typical 6CA7 fat bottle?
The Norh has the tubes sunk down in the chassis and the round cut-out won't accept a "true" fat bottle like a Sylvania or GE. So I was wondering before I bought the Ei's if they are in fact a big a round as the others.
Post edited by heiney9 on
  • george daniel
    george daniel Posts: 12,096
    good question--I have never paid attention to that,but I will look when I get home.
    I wanna' say that they will fit,,we'll see,,,good excuse for going home early today
  • george daniel
    they will fit-- the base of mine are the same diameter,,1.25" for both
    F1nut Posts: 51,793
    George, I'm pretty sure Brock is asking about the size of the glass, not the base.
    Brock, yes the Ei's are a true fat bottle size. Try the 6CA7 Treasures, they have a unique bottle design that would allow the tubes to sit lower.
    Thanks George and Jesse. Jesse is correct in that the Norh can't accomodate fat bottle type glass. The cut outs in the base aren't large enough and since the sockets are recessed it's too tight. I can barely fit the fat bottle Mullard GZ32 rectifier in it's place. It just fits but it's snug :biggrin:.
    On a different note do ALL Dutch (Sittard) made EL34's have a hole in the guide pin just like the British (Blackburn) made EL34's?
    Trying to date and find the place of manufacture for a pair I'm looking at. From what little I've read the Dutch tubes should also have a hole in the guide pin.
    The codes given by the seller do indicated early Dutch made as do the getters, but one tube has a hole the other has a "scored" part where the hole should be. Not paying top dollar for fakes or reissues or Matshushita made copies. I think the dbl "D" getters are the key and they are genuine.
    Anyone shed some light?
  • george daniel
    heiney9 wrote: »
    Thanks guys for helping an old man(me) understand the question,,lol,, Brock I have an Amperex Labeld NOS/NIB EL 34--that is definately a Mullard made tube,,mullard date codes,,hole in center pin,etc,,dunno if that helps--but I try. :smile:
    What are the codes George?
    xFx L7x is Sittard Holland
    xFx Bxx or Bxxx is British (Blackburn)
    5xx SYA or SY0 or SY1 or SYN or very early KEX are all Eindhoven Holland
  • george daniel
    I know that it's a Blackburn tube by the date code--,IIRC B?8,,another reason to go home early--thanks all.:smile:
    Trying my best :smile:
    I have a package here from Dave (DAGLJAM6) which has some blue glass JJ/Tesla EL34's he found in storage. So if anyone should go home, it's me :biggrin:.
    He's the one who sold me the Norh and promised if he ran across some old tubes he'd send them.
    Outstanding seller. Dave is a great Polkie :wink:
    As you can see in the photo neither have a hole in guide pin which has me scratching my head
    Keiko wrote: »
    OK... How much do you want for it, Brocko? :rolleyes: :biggrin:
    This vintage typically sells for $300 a piece.......................How's $299 plus shipping? :biggrin::tongue:
    JK................not going anywhere even though I have 3 of them. The others aren't as rare but still sound oh...so....sweeeeeet!!!!!!!
