Fosgate Audionics SD180 surrounds
Ceruleance
I finally put these on ebay with no reserve. Currently at 50 bucks, i'm told blue book is $450. If someone is going to steal them out from under me it would at least be nice to have it be someone from the club.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3071557025
These are huge surrounds. They have 2 vifa silk dome tweeters and 2 scan speak woofers per speaker. I haven't listened to these with the silk dome Rti's but I have with the tri-lam RTxxi's and they are fairly similar, I'd imagine they are even better at blending with the RTi's since they both have silk-domes. Does Vifa make the RTi tweeter, too? ( I know they make the famous LSi)
These are in good condition with a very minor mark on one of the corners.
Well, hit me up with any questions
Some pictures:
Some pictures:
Post edited by Ceruleance on
I have the Citation 7.3 surrounds. Are these pretty much the same?
my guess is that they are fairly similiar, probably not exact though. Harman bought out Fosgate's home division and they also owned the Citation group when the 7.3's were made.
If you want to pop your 7.3's open and confirm that you have a vifa tweeter and a scanspeak woofer, I would be happy to check the exact model numbers of my drivers against yours, that would be one way to tell if they are timbre matched at all .
my speakers are 22x14x9.5 HxWxD, that would be an easy way to check if its the exact same speaker just re-badged. -
Hey man don't sweat it - your item has over 4 days left. I seen the price of items go up 5 times in the last couple hours. I'm sure you will get what they are worth. I will be watching them. Good Luck.!!
Man, those are huge! My Citations are only 17 invhes high. I don't have enough room for 22 inches. I will be watching your auction though. Good Luck!
