TL Mod Question
intangible
intangible Posts: 262
edited December 2010 in DIY, Mods & Tweaks
I recently acquired a pair of SDA-2Bs thanks to a nice fellow in Indianapolis. I had planned on waiting a while before modding them, but with Sonic Craft's sale I figured I might as well go ahead and buy the parts to recap the crossovers.
I plan on doing the TL mod, but do not plan on purchasing new tweeters at the moment. If I can, I will go ahead and do the crossovers and let them start burning in, but I assume that the mod makes the speakers incompatible with the default SL-2000 tweeters? Thanks for any help.
Post edited by intangible on
  • george daniel
    george daniel Posts: 12,096
    never tried it with the "old" tweeters,,you would need the rdo 198's or sl-3000-- I'm sure that someone has tried it with the old tweets following the crossover upgrade,perhaps they'll chime in. Good luck and get some 198's :smile:
  • ben62670
    ben62670 Posts: 15,969
    It won't hurt anything. The high frequencies with just be a little stronger.
    Ben
  • intangible
    Oh, great! Thanks.
    F1nut Posts: 51,959
    They will not sound good, at all.
