Polk Audio RTI A7 and Onkyo TX NR808
aloha_mingalar
aloha_mingalar Posts: 5
edited December 2010 in Speakers
Aloha all,
I bought the Onkyo TX NR808, 2 Polk Audio RTI A7, Polk PSW 505, sony Bluray player and Samsung LCD. I setup last night after updating the latest firmware and did the audio calibration. Then i played the Dark Knight movie. THe picture looked great. However, the sound was not what i expected like watching it in the movie theater and i had a hard time hearing the vocal sound. The bass was not that powerful. Then i tried different listening modes. Pure audio only gave me mostly vocal sound but not the bass. Stereo gave more bass than vocal. Do i need more watt? Should i bi-amp the speakers? Is that anything i didn't setup correctly? What kind of setting do you recommend (+-db, Hz, etc... for both fornt & subwoofer speakers)? Any suggestion/advise would be appreciated.
Mahalo,
AM
Post edited by aloha_mingalar on
  • BluBitRates
    BluBitRates Posts: 68
    make sure your speakers are set to small. Make sure the subwoofer is actually working. I would set the subwoofer around 65% of its gain. Your problem is most likely subwoofer placement. If your cord is long enough set your subwoofer in your prime listening/watching position and then physically move around the room and find where the bass is the loudest. This is where you will want to move your sub to. Your tx-nr808 should have enough power for the 7s to player loud clear and with some midbass.
    Check your settings in the blu-ray player too. Give us some more detail,as in how is everything connected, how is the bdp connected,the subwoofer connected, etc.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Just to add to the already good starting advice....
    Pure Audio mode is a 2-channel mode only for front left and right speakers and the output to the sub will turn off - that is why you heard nothing from the sub in this mode.
    If after following the advice given above you still think dialog is not what you want - you may need a dedicated center speaker.
  • sandworms
    sandworms Posts: 1,043
    A better home theater set up would include a center channel speaker which carries the bulk of the dialogue. The Csia6 would be your best bet. Like Blu said, keeping your fronts set to something other than full range, probably 60 to 80h is best, that would give your sub most of the LFE and take some load off the avr. Looks like we have another hawaiin here Keiko
    Mahalo
    oops , Erik beat me to it
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
    Would be nice to know what is all in his setup. If he has only the 2 front speakers and a sub, he most likely has things setup wrong in the receiver and is loosing the information in the other channels thus not sounding good to him.
    WELCOME TO CLUB POLK!!
    +1, if you're only running 2 speakers and a sub you need to set those speaker to full range and use the Double bass feature on the Onkyo for HT. You would then select something like Theater Dimensional (sound) on the Onkyo to simulate surround sound? I use that option in my bedroom with two Rti-4s (of course I don't use the full speaker setting on the bookshelves), an Onkyo and an 8" sub and it does a nice job for movies!
    cnh
  • aloha_mingalar
    Thanks all. I have bi-amp the A7s, They sounded better especially the woofer. However, i am still having hard time hearing the vocal sound.
    I use HTMI (10 gbs) to connect Blu Ray, receiver, and TV. Monster wires to connect RTI A7s (bi-amp - SURR Back L/R to the High and Front L/R to the Low) and monster THX cable to connect the Subwoofer.
    My room size is about 12ft x 12ft. I have left 6 inches gap between speaker and the wall.
    The speaker placement order is Left speaker, TV, Right Speaker and then Subwoofer.
    Below are the receiver configration:
    Speaker Impedance: 6 ohm (4 or 6 ohm)
    Speaker Type: Bi-amp (Front)
    Front Speaker: 40 Hz
    Subwoofer: Yes
    LPF of LFE 120Hz
    Level Calibration
    Left: - 5db
    Right: - 6.5db
    Subwoofer: - 3.5db
    THX setup
    THX ultra2/select 2 Subwoofer: NO
    Loudness plus: ON
    Audio Adjustment
    Dolby
    Panorama: OFF
    Dimension: 0
    Center Wide: 3
    Neo 6 Music
    Center image: 2
    Theather dimension
    Listening Angle: Wide
    Please advise if there is anything that i need to change to make it sound better.
    Does the center speaker help with the vocal sound? But I never heard of 3.1 setup ??? Do you mean i need 5.1?
    Mahalo,
    AM
  • Upstatemax
    Upstatemax Posts: 2,783
    The two things that jump out at me:
    1- change the speaker impedance to 8ohm
    2- Change the front crossover to 60hz and let the sub handle anything below that.
    Yes, a center speaker makes a big difference...
    I ran a "3.1" system when I first got into HT... Just front towers, center, and a sub.
    The Onkyo only has setting for 6 (8ohms) or 4 ohms. So 6 ohms is the correct setting for Rtis.
    Try the TDimensional surround option I mention above, see if that helps with the midrange, vocals. You can also go into the EQUALIZER settings and pop up those frequencies?
    Finally, Onkyos have a CINEMA FILTER...try to find that option and try it both ON and OFF and see what that sounds like. This is a filter that tones down the brightness associated with mixes made for Large Commercial Theaters that may sound too bright in your house! But perhaps you need that PUSH with your set up.
    Good Luck.
    cnh
  • Gulfstrings
    Gulfstrings Posts: 313
    Subwoofer: Yes
    LPF of LFE 120Hz
    Level Calibration
    Left: - 5db
    Right: - 6.5db
    Subwoofer: - 3.5db
    THX setup
    Loudness plus: ON
    Audio Adjustment
    Dolby
    Panorama: OFF
    Dimension: 0
    Center Wide: 3
    Neo 6 Music
    Center image: 2
    Theather dimension
    Mahalo,
    AM
    The center is the most important speaker in any HT setup, IMHO. I ran my setup (below) for a year without adding the NAD amp and it was very good. But without the center it would be missing too much - in particular, the movie's dialogue.
    I don't know your sub, but I ran my setup with two PSW111 before bringing in the Velodyne and it was fine. From what I read here, the 505 is a good sub and I can tell you the A7s aren't puny when hitting the bass on their own!
    I have the Onk 707 and (from memory) believe you have your settings similar to mine which I think are "correct," though I've never actually chosen any of the processed options (Neo, etc) when listening or watcing.
    I did, before the NAD however, listen to music using the Pure selection. For movies I've always allowed the Onkyo to read the source and automatically adjust.
    You have a heck of a foundation there. Please look at either the CSi4 or CSi6as your next investment.
    It will have you hearing voices.
    The good kind ... like when your at Buzz's in Lanikai.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
  • aloha_mingalar
    Thank you all. Let me play with the setting first. If it doesn't work out then i will probably get the center speaker if my wife allows me so.
  • dorokusai
    dorokusai Posts: 25,576
    Just tell her it's life or death....with every center speaker an angel gets its wings.
  • Snowdogyyz
    Snowdogyyz Posts: 37
    Without a center channel, it's definitely not going to sound like going to a theater!
    Denon 4311CI
    Emotiva XPA-3
    Oppo BDP-83
    Polk RTiA7 fronts
    Polk CSiA6 center
    Polk FXiA6 surrounds
    Polk PSW505 sub
    Harman Kardon HK3490
    Monitor 70
  • aloha_mingalar
    I have a couple technical questions.
    What does the Hz do in the speaker config? My front speaks were setup by Audyssey as 40Hz. It can be adjusted from 40Hz to 120Hz, Full Range and THX (80Hz) options.
    What does +-db do? I tried it the lower the louder. Will it hurt either the speakers or receiver if i tune it to the extreme?
    Please advise.
    AM
  • aloha_mingalar
    For the center speaker do you all recommend Blackstone TL speaker?
  • nguyendot
    nguyendot Posts: 3,594
    My Onkyo 807 set my sub to -15 when it did calibration, resulting in NO bass. I turned it up to -5 and the car outside had a cracked windshield (no, not really).
    I used the supplied microphone on a tripod too.
    Main Surround -
    Set all your speaker levels to zero and go up or down from there. In your setup menu for the blu-ray player, did you tell it you don't have a center ? If so, change it to a yes and let the receiver route the signals. Which btw, did you setup the speakers in the receivers menu ? Tell the receiver you have no center or surrounds so those signals get routed to the front 2.
  • nguyendot
    tonyb wrote: »
    Setting anything on the bluray other than "bitstream" will have no effect.
    The settings for speakers only applies to using the internal decoder and analog outputs.
    It should be set to "bistream" for his NR808, so that it sends the untouched audio to the receiver, and from there it will determine what signals to send. If he ran the auto calibration, it will also know if he has a center or not. The first test determines how many speakers there are.
    Main Surround -
    Your absolutely right, I missed that somehow, that he ran his auto calibration. Sucks getting old.:biggrin:
  • I am in similar dilemma , i like the rti a7 and is sold on it just that not able to decide on the suitable amp for the same as my budget is max $1000 for the amp . Some shops have suggested a AVR which when hooked up does not sound good . All the integrated amps with power of 150 *2 are in the range of $3000 . Someone can share some insights
    F1nut Posts: 51,962
    Buy used.
  • I also buy used and refurbished. It's the only way I can kind of afford my hobbies.
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
