Looking to buy an amp... advice needed
djperez81
I want to purchase an amp to hook up to my HT setup i want a 3ch for my front stage but might be out of my price range(200-300) but if i get a 2ch to hook up to my rta 11t's will my center still sound good. Also by adding the amp do you use only the power of the amp or does it use the power from the amp and receiver combined. i dont mind buying a used amp if it is in good working condition. So any help here would be greatly appreciated thanks.
Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix
-Jimi Hendrix
Post edited by djperez81 on
You can get more for your money buying used and can find good deals on here if your patient. Once you connect an amp you are essentially removing the load from your AVR so that the amp is driving the speakers on the channels connected. I would look for a 3 or even a 5 channel amp.
your AVR should drive the center just fine but the upgrade bug bites often!
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
any recommendations on an amp would be helpful alsoMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Knucklehead wrote: »You can get more for your money buying used and can find good deals on here if your patient. Once you connect an amp you are essentially removing the load from your AVR so that the amp is driving the speakers on the channels connected. I would look for a 3 or even a 5 channel amp.
If used for home theater more than music, wouldn't you want to amp your center channel more than the others, since most (90%) of the sound effects come from the center as opposed to any other speaker.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Adcom 555 $300
Adcom 545 $200 -
good point, thats why i suggested a 3 or 5 channel.
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
www.audiogon.com is your friend. look at 3-5 channel amps. Be patient and save more money so that you only have to do this particular upgrade once. Get an amp that has at least 200wpc @ 8ohms. This will drive your RTA-11T's just great as well as any future speakers you might get. Brands to look for are:
Rotel, Parasound, Sunfire, Adcom, Outlaw, Emotiva, (both of the last 2 are reasonably priced new as well) B & K, Nad.
Good luck.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
i was looking at the emo xpa3 which is nice but wife wont let me spend that much :frown: she says we could do better things with our money but i beg to diifer. any other 3ch that anyone will recommend?Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
djperez81, Yeah thats usually the story around my house as well
I would seriously consider a used Adcom, Rotel etc... I picked up my Rotel on here for $200 I think, I have it bridged 3x150, and it sounds fantastic. check your local Craigslist and as cfrizz mentioned Audiogon.com, oh yeah ebay may turn up something. You may want to post a "wanted" ad here as well, it seems some of these guys have all kinds of stuff laying around.
DavidPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
thanks for info knuckleheadMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
As stated several times in this thread, you can save yourself a lot of money by purchasing used via Audiogon or here at CP.
Generally speaking, if the seller has an excellent feedback record and the condition of the product is rated high (8/10 or 9/10), you will likely be very happy with the results. -
anonymouse wrote: »Look for a Carver AV705X. Its 5 channel and if you are patient can get it for 300 bones or less. Its a fantastic amp for the price.
Is that the one I sold you ? Did you ever get that one channel fixed ? Agree, It is a nice amp for the price. Glad your enjoying it.HT SYSTEM-
lsi 9's -
Save up your money ($500-800ish) and buy a solid 3 or 5 channel amp from Parasound or Rotel, used off Audiogon or this site. I couldn't be happier with my current amp at this point.
Listen to your wife. It sounds as if she's been doing some research here!
I sold an xpa-3 to buy the previously owned amp I have now. I have no regrets about having tried Emotiva. It was a learning experience. -
I ran a 3ch and a 2ch for my setup. Aragon and Acurus made some nice amps back then under Mondial.2Ch Tube Audio Convert
There is a used Adcom 7500 on Craigs list near me for $400. If you could get the seller down to $350 (figure $50 to ship) would that work? I could go check it out on your behalf.
It's a 5 channel amp rated thus:
Power Rating
-150 watts continuous average power into 8 ohms at any frequency between 20Hz to 20kHz with all channels driven at less than 0.075% THD.
-225 watts continuous average power into 4 ohms at any frequency between 20Hz to 20kHz with all channels driven at less than 0.075% THD.
Signal to Noise Ratio, "A" Weighted (150 watts into 8 ohms) >115dB
Gain29dB -
Do you think the Adcom would be a good amp to power LSi 25 and LSi center and rears. Or what about a rotel RMB-1075.
That would be a great unit. IMHO the Rotel is in the same league.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks and it fits my budget.
jinjuku thanks for the generosity but its a little out of my budget at this time.Might just wait and save up a little more money.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
You got PM2Ch Tube Audio Convert
