Looking to buy an amp... advice needed
djperez81
djperez81 Posts: 388
I want to purchase an amp to hook up to my HT setup i want a 3ch for my front stage but might be out of my price range(200-300) but if i get a 2ch to hook up to my rta 11t's will my center still sound good. Also by adding the amp do you use only the power of the amp or does it use the power from the amp and receiver combined. i dont mind buying a used amp if it is in good working condition. So any help here would be greatly appreciated thanks.
Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix
Post edited by djperez81 on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited December 2010
    You can get more for your money buying used and can find good deals on here if your patient. Once you connect an amp you are essentially removing the load from your AVR so that the amp is driving the speakers on the channels connected. I would look for a 3 or even a 5 channel amp.
    your AVR should drive the center just fine but the upgrade bug bites often! :)
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • djperez81
    any recommendations on an amp would be helpful also
    -Jimi Hendrix
    nooshinjohn Posts: 25,907
  • nguyendot
    nguyendot Posts: 3,594
    If used for home theater more than music, wouldn't you want to amp your center channel more than the others, since most (90%) of the sound effects come from the center as opposed to any other speaker.
    Main Surround -
  • leroyjr1
    leroyjr1 Posts: 8,785
    Adcom 555 $300
    Adcom 545 $200
  • Knucklehead
    nguyendot wrote: »
    good point, thats why i suggested a 3 or 5 channel. :wink:
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • cfrizz
    cfrizz Posts: 13,415
    www.audiogon.com is your friend. look at 3-5 channel amps. Be patient and save more money so that you only have to do this particular upgrade once. Get an amp that has at least 200wpc @ 8ohms. This will drive your RTA-11T's just great as well as any future speakers you might get. Brands to look for are:
    Rotel, Parasound, Sunfire, Adcom, Outlaw, Emotiva, (both of the last 2 are reasonably priced new as well) B & K, Nad.
    Good luck.
  • djperez81
    i was looking at the emo xpa3 which is nice but wife wont let me spend that much :frown: she says we could do better things with our money but i beg to diifer. any other 3ch that anyone will recommend?
    -Jimi Hendrix
  • Knucklehead
    djperez81, Yeah thats usually the story around my house as well:tongue: I would seriously consider a used Adcom, Rotel etc... I picked up my Rotel on here for $200 I think, I have it bridged 3x150, and it sounds fantastic. check your local Craigslist and as cfrizz mentioned Audiogon.com, oh yeah ebay may turn up something. You may want to post a "wanted" ad here as well, it seems some of these guys have all kinds of stuff laying around.
    David
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • djperez81
    thanks for info knucklehead
    -Jimi Hendrix
  • Beta
    Beta Posts: 267
    As stated several times in this thread, you can save yourself a lot of money by purchasing used via Audiogon or here at CP.
    Generally speaking, if the seller has an excellent feedback record and the condition of the product is rated high (8/10 or 9/10), you will likely be very happy with the results.
    tonyb Posts: 33,072
    anonymouse wrote: »
    Look for a Carver AV705X. Its 5 channel and if you are patient can get it for 300 bones or less. Its a fantastic amp for the price.
    Is that the one I sold you ? Did you ever get that one channel fixed ? Agree, It is a nice amp for the price. Glad your enjoying it.
  • kevhed72
    kevhed72 Posts: 5,139
    Save up your money ($500-800ish) and buy a solid 3 or 5 channel amp from Parasound or Rotel, used off Audiogon or this site. I couldn't be happier with my current amp at this point.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    djperez81 wrote: »
    Listen to your wife. It sounds as if she's been doing some research here! :wink: I sold an xpa-3 to buy the previously owned amp I have now. I have no regrets about having tried Emotiva. It was a learning experience.
  • aboroth00
    aboroth00 Posts: 1,106
    I ran a 3ch and a 2ch for my setup. Aragon and Acurus made some nice amps back then under Mondial.
    2Ch Tube Audio Convert
  • jinjuku
    jinjuku Posts: 1,523
    There is a used Adcom 7500 on Craigs list near me for $400. If you could get the seller down to $350 (figure $50 to ship) would that work? I could go check it out on your behalf.
    It's a 5 channel amp rated thus:
    Power Rating
    -150 watts continuous average power into 8 ohms at any frequency between 20Hz to 20kHz with all channels driven at less than 0.075% THD.
    -225 watts continuous average power into 4 ohms at any frequency between 20Hz to 20kHz with all channels driven at less than 0.075% THD.
    Signal to Noise Ratio, "A" Weighted (150 watts into 8 ohms) >115dB
    Gain29dB
  • butter21
    butter21 Posts: 19
    Do you think the Adcom would be a good amp to power LSi 25 and LSi center and rears. Or what about a rotel RMB-1075.
  • ben62670
    ben62670 Posts: 15,969
    That would be a great unit. IMHO the Rotel is in the same league.
    Ben
  • butter21
    butter21 Posts: 19
    Thanks and it fits my budget.
  • djperez81
    jinjuku thanks for the generosity but its a little out of my budget at this time.Might just wait and save up a little more money.
    -Jimi Hendrix
  • aboroth00
    djperez81 wrote: »
    You got PM
