Can You Use Banana Plugs with Polk Montor 60's?
Billy1941
I was all set to install banana plugs on my setup, but found that apparently my Monitor 60's will not accept banbana plugs. Just tie down on the posts.
I have figured it out and no longer need any help. But thanks anyway.
Post edited by Billy1941 on
I believe alot of polk speakers have little caps over the binding posts that you can pop off and then use a banana plug. I enjoy banana plugs for no reason but asthetics
