breaking in speakers
body count
I keep reading about breaking in speakers. I just got a killer deal monitor 60s (week old), and today got a killer deal on monior 50s and cs1. I've googled for info, with no luck. I have turned them up a couple times, but scared to hurt them so i've been easy on them. As you can see the speaker can handle my receiver with no problem, What are the do's and don'ts with polk speakers.
onkyo tx-sr 606
front m60
rear m50
center cs1
onkyo tx-sr 606
front m60
rear m50
center cs1
Post edited by body count on
Do play them. Don't turn the receiver up too high.
They'll break in with normal usage. Rear speakers generally take longer as they don't have as much content going to them.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
You *can* run the receiver in an "all ch stereo" mode to get full range program material to all of the speakers for break-in purposes. A couple weeks worth of regular listening should do the trick.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
