Need advice on rears and subwoofer for a new setup.
Ive decided to gear up my HT and Im upgrading from a 7.1 HTIB.
The receiver is probably going to be an Onkyo NR708. I just bought a pair of Polk Monitor 40s and a center CS2 (couldnt resist a great deal from newegg). For the subwoofer, I was considering a PSW10, but Ive been reading that it is just ok and there are much better options.
My question is: should I mix-in something else besides Polk for my subwoofer? or should I consider a PSW505 instead? Also, for the rear/surround Id like to add a pair of OWM3s. Is that a good choice based on my setup?
My room is mid-size and I want to start with 5.1, my budged is ~300 left for surround and subwoofer. I could start with a 2.1 system and add surround eventually.
Thanks for input
Thanks for input
Post edited by oneteam on
WELCOME TO CLUB POLK!!
The PSW505 is a best buy budget wise for an older Polk sub. Still better than any Polk sub in the PSW series today including the PSW125--and, as you point out, it can be had for less coin.
The rest of your system looks very good!
You can run a 3.1 system for a while and be fairly happy till you pick up some M40s or M30s as rears?
+1 on the psw 505 way better than the resst of the psw and if your like me nd like to be matched go for it.if your budget is higer than hsu vtf3 mk3 would be my opinion not there on.the.dollar eda2 300 would be.in.between.both.mentioned!! Good luck!Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3 -
+1 again on the PSW505 over a PSW10. I have two and am happy with them. buying rears may stretch your budget but the 505 over the 10 is worth it. Like CNH said you could run 3.1 for a while and save up for monitor 60 or 70 fronts and put the 40's in the rear. If you stick around the forum enough, trust me that thought will start bugging you. 30's in the rear would be great though. That would be a solid system.System:
Samsung LN46C630
Receiver: Yamaha RX-V1
DVD/Blu: Denon 2910/Playstation 3
Front mains: RT16
Front presence: F/X 500i
Center: CS400
Rear surrounds: RT1000p
Rear center: RT7
Subwoofer: PSW505 X 2
Marantz 2252B
Technics SL-Q2 turntable
Kef Q50
