Best Solder Station
AudioGenics
AudioGenics Posts: 2,567
edited March 2011 in DIY, Mods & Tweaks
best solder station for the money ?
Post edited by AudioGenics on
  • ben62670
    ben62670 Posts: 15,969
    edited November 2010
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=374-100
    I have a few, and I gave some away to friends. Never had an issue. Works great.
    Ben
    Ben
  • Face
    Face Posts: 14,340
  • [Deleted User]
    [Deleted User] Posts: 1,223
    Surface mount or through hole ? For surface mount Met Cal makes a decent unit that will do through hole as well. If its for general type stuff and through hole, I've had good luck with the Weller's. Make sure you get one with adjustable temperature. :cool:
    nooshinjohn Posts: 25,985
    +1 for the Weller... mine is the same model as being sold on Amazon, and it is well balanced and precise. It heats up quiclky and has an adjustable temp cotrol. I love it.
  • AudioGenics
    OMG !
    Metcal Soldering Station, MX-5000 Series
    by OK INTL / METCAL
    Price: $1,010.00
    I appreciate the suggestion
    and the Weller is really nice too
    but for $10.00 and another $4.95 for extra tips I'm ordering the Stahl.
    THANKS Ben62670
    Left my Weller Station at my parents home.
    I got a Cooper iron on a weller cast stand with a homemade controller.
  • ben62670
    You will be very happy with it. Mine is running right now doing a set of XO's.
    Ben
  • Rev. Hayes
    Rev. Hayes Posts: 475
    I have a Weller gun (great for the grunt work) and a Radio Shack pen.
    I've lusted after the Weller station for some time but at that price (and the endorsement of Ben) the Stahl looks like my next purchase.
    Sounds good to me...
  • [Deleted User]
    OMG !
    by OK INTL / METCAL
    Price: $1,010.00
    THANKS Ben62670
    The Met Cal is what we used at 5601 Metro Drive. Like I said mainly for SMA and very delicate soldering. As far as the price it was on Matthew Polk's dime.
    Sorry but it did spoil me. The weller is what I use at home and works well for a variety of applications. :cool:
  • strider
    strider Posts: 2,568
    Taking the price into consideration, the Stahl's a good unit. The tip has fallen out of mine after using it for a full morning, our dining room table is now antiqued. The cord from the iron to the base is captive, and gets difficult to get the twists out. For $10 bucks I can deal with that.
    If I were looking to buy one without the thought of replacing it in a year or so, I'd go with the Weller Face linked to.
    Wristwatch--->Crisco
  • dorokusai
    dorokusai Posts: 25,576
    Face wrote: »
    Agreed, although I like the digital model. Excellent unit, either way.
    Weller is the name you want on your work desk and I paid around $65 for mine.
  • ben62670
    The tips do need to be snugged up pretty tight. After a few heat cool cycles the tip hasn't loosened in a long time. The tips are very nice and have some mass to them. That is very helpful when doing a large joint, or tinning a heavy connector.
    Ben
    Ben
  • TECHNOKID
    TECHNOKID Posts: 4,298
    dorokusai wrote: »
    Yep, I'd never go for anything else than a weller (I've been spoiled, I admit :cool:)!
    Unless one can afford a PACE Soldering station http://www.paceworldwide.com/# you might as well stick wit Weller :wink:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • HB27
    HB27 Posts: 1,518
    Weller. I've been using them for years with no major issues. I've had to replace the cords, heating elements, and tips, but all the Wellers fit your finger grip, don't overheat your fingers, and work.
    I worked a bench for years and it's all I'd ever use.
    I've got a drawer full of off brand soldering irons I've bought over the years that just don't get used because they're uncomfortable to use and awkward.
    ECG has a nice 20w iron that heats up in a few seconds and heats to about 650 degrees that's nice for a "road box" iron. They're cheap.
    I'm going to order the Stahl just to check it out. Looks very good for the $$.
  • TECHNOKID
    Hey, you sure can Karma them my way! I'd love to participate in cleaning up that drawer with you. You can thank me later :wink:
    DARE TO SOAR:
  • inspiredsports
    inspiredsports Posts: 5,502
    Rev. Hayes wrote: »
    Don't let Doro see the "I have . . . Radio Shack pen" part of your post :biggrin:
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • fatpiggy
    fatpiggy Posts: 205
    I have a basic Hakko solder station and Im very happy with it.Its a well known brand in the electronics industry, possibly a little bit more expensive than Weller.Weller is also a good brand.
    Fatpiggy
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited December 2010
    I got this one last summer, and am very happy with it.
    http://www.amazon.com/Hakko-Soldering-Station-936-Iron/dp/B000ARU9HW
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • audiobilly
    audiobilly Posts: 351
    ^^^^^^Yes^^^^^^+1
    Great Bang for the buck. Been using these Hakkos' professionally for 15+ years. Got one at work and one at home.
  • jinjuku
    jinjuku Posts: 1,523
    I would vote for the Hakko.
    Here is an Aoyue 937 digital unit that will work with Hakko tip's.
    http://www.amazon.com/Aoyue-937-Digital-Soldering-Station/dp/B000I30QBW/ref=sr_1_2?ie=UTF8&qid=1291396375&sr=8-2
    Can't speak personally to this Iron, just wanted to point it out. You will have to use the Amazon review section to make up your own mind.
  • JimAckley
    JimAckley Posts: 1,138
    edited March 2011
    Sorry for the thread revive, but I was wondering what you guys thought about this Stahl TCSS station.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=374-200
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
    pitdogg2 Posts: 27,236
    edited March 2011
    for the price looks good when my 20.00 dies may step up if still on sale, but then again the one Ben recommended works GREAT
  • bkeane1259
    bkeane1259 Posts: 54
    edited March 2011
    I don't think there is a better "bang for the buck" soldering station as that one, and they are in stock again FYI. PE sometimes runs out of these and for good reason!!
    Stahl Tools SSVT Variable Temperature Soldering Station
  • Systems
    Systems Posts: 14,872
    edited March 2011
    I bought one on Ben's advice and I love it.
    Testing
    Testing
    Testing
    F1nut Posts: 51,953
    edited March 2011
    Weller.
  • headrott
    headrott Posts: 5,496
    edited March 2011
    Weller.
    Yep.......
  • CoolJazz
    CoolJazz Posts: 572
    edited March 2011
    For potential solder slingers, maybe this would be a good place for this...
    http://www.youtube.com/watch?v=I_NU2ruzyc4%26feature=related
    Do yourself a favor and take the time to watch it!
    On my home bench, I use and love a Hakko station and a Pace desoldering station.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • HB27
    HB27 Posts: 1,518
    edited March 2011
    "IF you can shoot pool you can use a broomstick"
    Learn how to use the iron before digging into good gear.
    Yea, you know who I'm referring to!
    Tony M Posts: 11,681
    edited March 2011
    CoolJazz wrote: »
    CJ
    Thanks for posting that video.:wink:
    I did learn something tonight. I'll rewatch that again later when I do some more soldering on a board or something.
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited March 2011
    Just got my Weller WES-51 Soldering Station the other day, along with an assortment of tips. It did not come with a sponge, damn it!!! Oh well, time to break out the cutters and make a specialized sponge that will fit the tray.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • PolkMaster1
    edited March 2011
    CoolJazz wrote: »
    CJ
    Did anyone notice that the author of that video was using a Weller for the soldering and the (c)rust formed soldering pen was a radio shack pen?
    Cant wait for the flux to arrive before I start to use my Weller station!
