Emotiva XPA-3
AR15223
AR15223 Posts: 13
edited November 2010 in Electronics
Wondering if I should get a amp with the setup i am running? Would this make a huge difference. How is the amp connected to the receiver? Are the speakers connected to the the amp or receiver still?
Home Theater Setup
Receiver: Yamaha RXV 665
Fronts: Polk Audio Monitor 60
Center: Polk Audio CS1
Rear: Polk Audio TSI 300
Sub: Polk Audio PSW 505
BluRay: PS3 Slim
Xbox 360
Display: Insignia 1080p 50" Plasma
  • cnoat
    cnoat Posts: 315
    I don't have any exp.with the emotiva.But if your reciever has pre outs you run the pre outs to the amp.Your speakers are hooked up to the amp.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
    EndersShadow Posts: 17,715
    AR15223 wrote: »
    If your receiver has preouts you connect an cable from the pre-outs to the amp for the channels you want run from the amp. You then connect those speakers to the amp rather than the reciever.
    Will it make a difference: YES!
    I noticed a big difference in music when listening to my Monitor 60's on a 125wpc 5 channel amp. I can only imagine the difference you would hear with the XPA-3 which has much more wpc than my Carver.
    F1nut Posts: 51,899
    Your thread title doesn't seem to have anything to do with your questions.
    Does your AVR have pre outs?
    Too subjective. What might be huge to one person may not be huge to another. Will adding an amp make a difference? Yes.
    Thru the pre outs on the AVR.
    The amp.
