Old car, new stereo, need advice
madcat69
I've got a '69 Cougar that is need of a stereo. I'm not currently planning on installing front speakers since there isn't much room in the doors. What I'm looking at is some 6x9's in the rear and subwoofer. I love my Polk Audio home theater gear so I'm looking at their car audio. I like hard rock/metal but when I listen to more mellow tunes I want decent sound quality. Here's what I'm thinking so let me know if you think it will work.
MM691 6x9s
PA250.2 Amp
MM1040 Sub (mounted in trunk)
PA400.1 Amp
Since there is no back seat in the car, the rears will be mounted so that they are aimed to the front.
MM691 6x9s
PA250.2 Amp
PA400.1 Amp
Post edited by madcat69 on
I'm not familiar with 69 Cougar (or any other older car lol) but by any means possible try to not have good speakers in the rear and none (or crappy) in the front. Sound will be totally screwd up and will sound NOTHING like Polks you have at home since it's be coming from the rear.
2-channel home system is speaker in front of you
going to a concert - speakers in front of you
See where i'm going with this?? lol2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
I see what you're saying. Old cars like this one didn't have any provisions for door speakers and the window mechanism gets pretty close to the one open area where I could mount them. I'd be limited to very small speakers.
Given that I'm kinda stuck with rears only, are the amps a good match for the speakers? -
If you have space in your foot-wells, how about kicks?
Driver side is really limited. The emergency brake is there. I've thought about converting to a hand brake between the seats, but not ready to tackle that yet.
Could go with a 4 channel amp and add fronts down the road when I have the time and energy.
There was a place in the dash for a single speaker. Car originally had an AM radio and that was it. :frown: Stereo equipped cars had speakers mounted in the back.
I think I'll be OK for now as long as the components work well together. -
So is it the depth that will be the problem with front? Have you considered getting shallow mount speakers. You may not be able to do 6x9's in the front, and only able to do 3"-6" round speakers.
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org -
The largest speaker I could put there would be a 3". Any larger and it interferes with the window mechanism or the cover would hit the manual window crank.
I have owned a couple of these cars. If memory serves correctly I think there may be a perforation on the backside of the door panel near the door front for factory speakers. There is no room behind the kick panels and I would not put speakers there because the cowl vents are prone to rot and leaking in this area. But definitely check out the door panels you may be pleasantly surprised. :cool:
One thing I forgot to mention. These cars are Mercury's version of a dressed up Mustang. There is a wealth of information on Mustangs so see what is common for the 69 Mustang. :cool:
Nope. No perforations. Might have a chance if I had power windows.
nap, do you think the amps are good enough to get good volume and clean operation out of the 6x9's? -
btw looking at your amps - yes, they will do the job just fine.
buuut
- instead of PA400.1 i'd go with 600.1 simply for the sake of having that extra power.
Also for the price of 2 amps on your list i'd probably get PA1100.5 which will be about the same size as 400.1 and 250.2 (combined) but will also have those "extra" 2 channels u might need in the future when u figure out what to do with front speakers.
PolkDirect sells 1100.5 for just over $200 refurbished but don't be scared of "refurb". It's direct from Polk, with warranty, in the box, manuals, hardware.... I actually got 1200.1 from them and it looks brand freaking new. No dings, scuffs, imperfections - nothing. I think they just wanna get rid of some stuff to make room for new models and selling then as "refurb" since they can't sell as "new" for those prices lol.
But yes, amps u got will work fine.2008 Nissan Altima
Kenwood DNX 5140
Si. :cool: -
MM691 6x9s
PA250.2 Amp
PA400.1 Amp
BTW - I was curious if you were doing a restore on this car or what kind of shape it was in. Maybe you could post some pics ? When it comes to vintage cars, I am always interested in this sort of thing. Best of Luck with it. Cheers. :cool: -
Thanks everyone for the good advice and help!
I built this car for drag racing and campaigned it in the 90's. New house, kids, etc kept me out of racing for years and the car gathered dust. I decided to do a "resto-mod" on it so I could drive it on the street. I'm leaving the roll cage in (hence no back seat) and a lot of the drivetrain. Should be fun to drive. :biggrin:
Here's a picture of what it looked like when I was racing. I'll post some pictures when I finish the interior and stereo install over Christmas (the stereo and seats are my gift to myself).
Have a happy Thanksgiving! -
Man that looks sweet. I always liked the Cougars with the hidden headlights and sequential turn signals. Too bad John Force doesn't race them. :cool:
