Mounted needed for Polk Audio 40
I need a good mount that will tilt these speakers in a 45 degree angle downwards, and swivel them around 20-30 degrees to the left and right.
Any ideas? I can use a ceiling mount also as these will be Heights for my setup.
Post edited by dzirkelb on
welcome to Club Polk
check out parts-express.com
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=372
maybe that would give you an idea of what is available -
look at my system showcase...i have pictures of what the speakers look like mounted with those AM40 mounts"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I saw that mount, and was hoping that would work...do I need to purchase anything extra for them to work? Will the 40's have the screw terminal to screw the mount into? -
my bad...my pics are of the wrong mounts...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I've never had the 40's but if i remember right they don't have the keyhole on the back to mount, I think you just need to put one of your choice on the back of each speaker. Please correct me if i'm wrong, I had the 30's and it was very easy to do.
