Which one? Onkyo HT-RC160 or Denon AVR1910
ROHfan
ROHfan Posts: 1,014
edited November 2010 in Electronics
I've narrowed it down to two receivers that are within my reach. The Onkyo is $150 at a local PC Richards as an open box item. The Denon can be had refurbished for $285.
I've seen both of these talked about here but if it's between the two which would you get? I want to upgrade so that I can have HDMI inputs and get some better sound than my older Denon VR507 can put out. Of course, adding two more surround channels is appealing since I have two Polk R150's just layin' around! I'm using R50's as my fronts.
Thanks in advance.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • tina902
    tina902 Posts: 25
    hey, let me test this, first post would't work
  • tina902
    tina902 Posts: 25
    I've been off here 4 over a year & need huge
    help ipcking out an av receiver & figuring out what I really need & don't need . I know the entry level ones by denon & onkyo are rated really good but, I'm not diggin the black look, though, the onkyo looks prettier, both under 200.00. Harmon kardan has a gray on black which is okay. But, I liked the silver & black better, were those the older models? I now see them on ebay refurbished from HK. I really want one of those but fear its outdated? However, If I buy a newer blue-ray, won't it offset what the older H. kardon unit lacks?? what do I really need anyway?? I'm hearing will it pass music thru hdmi? is it a repeater? what the hecks that & does it matter except in the bdrm?! I know the onky/denon will have all the latest stuff so, I guess I'm wondering if the 2-4 yr. old silver & blk. harmon kardons will have all I need. Honestly., I only watch dvds about 2-3 times a month & the picture is fine...+ a few dvd rock videos. I have a cheap doorbuster 10.00 coby dvd player & a tube tv with no cable (by choice) yes, rabbbit ears...(nothing worth watching these days) I appreciate a good picture & get plenty of hd channels that look very pretty.But, don't care if the zit on the actor's face is super visable or just visable! Can someone assist before I just buy a HTIB..LOL!
    tina
  • John K.
    John K. Posts: 822
    ROH, although I more frequently suggest an Onkyo model, in your case, if the added cost of the 1910 isn't crucial I'd suggest it. The main reason is that it has the superior Audyssey MultEQ version while the 160 has the simplified 2EQ. The MultEQ offers more measuring positions for greater accuracy, and maybe more important, it equalizes the sub channel, while the 2EQ doesn't.
  • John K.
    John K. Posts: 822
    Tina, I'd suggest that you don't worry about what colors that you're "diggin" and get an excellent receiver at a very good price, such as the Denon 1910 which ROH is considering.
  • ROHfan
    ROHfan Posts: 1,014
    John K. wrote: »
    Thanks, John K, I was kinda leaning towards the Denon so I feel a little better now.
