Krell TAS Theater Amp Standard
screename
Just thought I would throw this up here as well.
I will take 3500 shipped for Polkies. Listed elsewhere for 3700 not shipped.
Thanks for looking.
Thanks for looking.
Post edited by screename on
Sorry to derail but what Wilsons are you running?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Some Maxx's...not sure how you could see em from those shots... lol.
In the third pic I could see the corners...
Sweet setup!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
you guys are impressive !
Wish I had the cash
Some dreamy krell gear ya have there bud -
All that power and it's a krell and you can't use an aftermarket power cord?, Very weird.
Good luck with your sale!
It's a very thick power cord and while I'd like the ability to change it out, it's one of the last things I could care less about when owning a 100+lb amplifier. The cord(g) is more than enough to handle anything that could possible be thrown at it.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Krell gear doesn't afford the option. They are particular about power conditioners as well.
Excerpt from the Manual:
AC POWER GUIDELINES
Krell recommends operating the Theater Amplifier Standard from a dedicated 20-amp
AC power line. The Theater Amplifier Standard should be used only with the AC power
cord supplied. Please contact your Krell dealer, distributor, or Krell before using any
devices designed to alter or stabilize the AC power for the Theater Amplifier Standard.
Manual is on this page: http://www.krellonline.com/manuals.html -
I think Krell tells people that they don't need anything special because the power supply in the unit cleans things up just fine. I might be confused though. Great gear you've got there.
swegyptian wrote: »I think Krell tells people that they don't need anything special because the power supply in the unit cleans things up just fine. I might be confused though. Great gear you've got there.
I agree with that explanation, of which can be found in depth elsewhere. The power supply in a hardcore SS amplifier does not need a power conditioner. It's also a backdoor recommendation from John Curl in regards to the JC1. That's for another day.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Specifications
FREQUENCY 20 Hz to 20 kHz +0 dB, -0.09 dB
RESPONSE 0.25 Hz to 170 kHz +0 dB, -3 dB
SIGNALTO NOISE
RATIO
A WEIGHTED >110 dB
TOTAL HARMONIC 1 kHz < 0.03%
DISTORTION (THD) 20 kHz < 0.20%
GAIN 25.8 dB
INPUT IMPEDANCE 100 kOhms
INPUT SENSITIVITY 2.05 Vrms
OUTPUT VOLTAGE Peak to Peak 113 V
RMS 40 V
OUTPUT POWER
EACH CHANNEL 8 Ohms 200 W
4 Ohms 400 W
BRIDGED 8 Ohms 800 W
POWER Standby 60 W
CONSUMPTION Idle 170 W
Max. 2500 W
INPUTS 5 single-ended via RCA connectors
5 balanced via XLR connectors
5 via DB-25 connector
OUTPUTS 5 amplifier channels via five-way binding posts
REMOTE CONNECTORS 12 VDC Out (12 V trigger) via a 3.5 mm connector
12 VDC In (12 V trigger) via a 3.5 mm connector
DIMENSIONS 17.3w x 9.8h x 17.0d in.
43.8w x 24.8h x 43.2d cm
WEIGHT
SHIPPING 110 lb., 50 kg
UNIT ONLY 100 lb., 45.5 kg
All operational features, functions, specifications, -
FWIW, Nelson Pass has the same backdoor explanation about Pass Labs and First Watt gear.
I have no doubt H9 and only used the JC-1 as an example.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
This weekend only 3K insured shipped to your door.
I got an email from a guy at Agon:
"Hi Screename,
I read on the Polk Audio boards that you're selling this amp to polkies for $3000 shipped. I'm not a polkie but for that price I'd buy it. Please let me know if we can have a deal
Thanks and best regards,"
THIS OFFER HAS EXPIRED.
