Krell TAS Theater Amp Standard
screename
screename Posts: 321
edited December 2010 in For Sale (FS) Classifieds
Just thought I would throw this up here as well.
I will take 3500 shipped for Polkies. Listed elsewhere for 3700 not shipped.
Thanks for looking.
Post edited by screename on
    VR3 Posts: 29,553
    edited November 2010
    Sorry to derail but what Wilsons are you running?
  • screename
    Some Maxx's...not sure how you could see em from those shots... lol.
    VR3 Posts: 29,553
    In the third pic I could see the corners...
    Sweet setup!
  • AudioGenics
    AudioGenics Posts: 2,567
    you guys are impressive !
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Wish I had the cash
    Some dreamy krell gear ya have there bud
  • dorokusai
    dorokusai Posts: 25,576
    Lasareath wrote: »
    All that power and it's a krell and you can't use an aftermarket power cord?, Very weird.
    Good luck with your sale!
    It's a very thick power cord and while I'd like the ability to change it out, it's one of the last things I could care less about when owning a 100+lb amplifier. The cord(g) is more than enough to handle anything that could possible be thrown at it.
  • screename
    Krell gear doesn't afford the option. They are particular about power conditioners as well.
    Excerpt from the Manual:
    AC POWER GUIDELINES
    Krell recommends operating the Theater Amplifier Standard from a dedicated 20-amp
    AC power line. The Theater Amplifier Standard should be used only with the AC power
    cord supplied. Please contact your Krell dealer, distributor, or Krell before using any
    devices designed to alter or stabilize the AC power for the Theater Amplifier Standard.
    Manual is on this page: http://www.krellonline.com/manuals.html
  • swegyptian
    swegyptian Posts: 316
    I think Krell tells people that they don't need anything special because the power supply in the unit cleans things up just fine. I might be confused though. Great gear you've got there.
  • dorokusai
    swegyptian wrote: »
    I agree with that explanation, of which can be found in depth elsewhere. The power supply in a hardcore SS amplifier does not need a power conditioner. It's also a backdoor recommendation from John Curl in regards to the JC1. That's for another day.
  • screename
    Specifications
    FREQUENCY 20 Hz to 20 kHz +0 dB, -0.09 dB
    RESPONSE 0.25 Hz to 170 kHz +0 dB, -3 dB
    SIGNALTO NOISE
    RATIO
    “A” WEIGHTED >110 dB
    TOTAL HARMONIC 1 kHz < 0.03%
    DISTORTION (THD) 20 kHz < 0.20%
    GAIN 25.8 dB
    INPUT IMPEDANCE 100 kOhms
    INPUT SENSITIVITY 2.05 Vrms
    OUTPUT VOLTAGE Peak to Peak 113 V
    RMS 40 V
    OUTPUT POWER
    EACH CHANNEL 8 Ohms 200 W
    4 Ohms 400 W
    BRIDGED 8 Ohms 800 W
    POWER Standby 60 W
    CONSUMPTION Idle 170 W
    Max. 2500 W
    INPUTS 5 single-ended via RCA connectors
    5 balanced via XLR connectors
    5 via DB-25 connector
    OUTPUTS 5 amplifier channels via five-way binding posts
    REMOTE CONNECTORS 12 VDC Out (12 V trigger) via a 3.5 mm connector
    12 VDC In (12 V trigger) via a 3.5 mm connector
    DIMENSIONS 17.3w x 9.8h x 17.0d in.
    43.8w x 24.8h x 43.2d cm
    WEIGHT
    SHIPPING 110 lb., 50 kg
    UNIT ONLY 100 lb., 45.5 kg
    All operational features, functions, specifications,
    heiney9 Posts: 25,515
    dorokusai wrote: »
    FWIW, Nelson Pass has the same backdoor explanation about Pass Labs and First Watt gear.
  • dorokusai
    heiney9 wrote: »
    I have no doubt H9 and only used the JC-1 as an example.
  • screename
    This weekend only 3K insured shipped to your door.
  • screename
    I got an email from a guy at Agon:
    "Hi Screename,
    I read on the Polk Audio boards that you're selling this amp to polkies for $3000 shipped. I'm not a polkie but for that price I'd buy it. Please let me know if we can have a deal :)
    Thanks and best regards,"
    THIS OFFER HAS EXPIRED.
