basic hookup
typhoonguy
I recently bought a pair of RTi100's for front HT use. I have a CSi30 center and rear RTi28's. Any suggestions as far as hookup? I read in product reviews of the 100's that if they are not hooked up properly their sound quality can be poor. Thanks.
Post edited by typhoonguy on
Try doing a search on this forum just type in "setup spreakers" should be a ton of reading for you. Good luck post if you still have problems.Wish I was a polkologist then I could call my self Dr.warviper.
typhoon,
What kind of receiver do you have and do you also have a subwoofer? -
Thanks for the reply, and the info. I have a Panasonic SA-HE70 receiver, and I do have a subwoofer, but it is from an Aiwa package home theater system, so I don't imagine it is of any quality.
