8ohm/4ohm volumn difference?
pearsall001
pearsall001 Posts: 5,324
edited November 2010 in Speakers
With my new LSi15's I'm noticing a hugh difference in the volumn setting on my pre as compared to my AAD 2001 monitors. The 15's are 88db/4ohm where as the AAD's were 86db/8ohm (which by the way were power hogs too). My new volumn settings are a good -8 to -12 down from my previous settings to achieve the same loudness levels. Not knowing too much on the technical end I would have assumed that the 4ohm load would have these settings in reverse. From reading here on the forum it's always pointed out that the LSi's are a tough load to drive. The amp has remained the same...Rotel RMB-1095 (200w@8ohm / 330w@4ohm). I do know that to increase the volumn by 3db you need to double the power which isn't the case here. What gives? This just has me curious as I know there's a very good technical reason for this. I'm getting my learn on.
Post edited by pearsall001 on
  • Face
    Face Posts: 14,340
    The 86db efficiency on your old monitors may have been an exaggeration.
  • AudioGenics
    AudioGenics Posts: 2,567
    to begin with a technical explanation
    we need to start with a specific description
    what measurement are you making?
    how exactly are you measuring HUGE ?
    i can see the responses now .........
    EndersShadow Posts: 17,715
    I would think that the reason it plays louder lower is that due to the decreased resistance to the signal (i.e. LSi 4 ohm v AAD 8 ohm) you get more power per increase in the volume than you did with your other speakers....
    Beyond that I dont want to speculate.
    The reason we say the LSi's are a tough load to drive is that many recievers cannot do 4 ohms. If your amp can handle 4 ohms (which yours can with power to spare) then its not a problem, however many folks inquiring about the LSi's are doing so while assuming they can run them off a standard Onkyo, Denon or Yamaha reciever which isnt the case.
  • pearsall001
    jvc wrote: »
    SPL meter at listening position along with these crusty 'ole ears!!! As far as describing any other HUGE diferences...I'll leave that up to you guys! :redface:
    I'm with you Phil. I experienced something similar between a set of LSI-7s (88db at 4 ohms) and a set of Energy RC-10s at 88db at 8 ohms. The LSIs, on the same amplifier, had a lower volume setting for the same loudness?
    I can't explain this either and defer to our experts.
    cnh
  • ben62670
    ben62670 Posts: 15,969
    4ohms allows more power to flow than 8ohms. So basically you are getting nearly twice the power at the same volume level which translates into 3db gain. I would not trust the DB numbers on your volume control.
    Ben
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    ^^^^ I experienced the same when I had 4 ohm speakers switched from 8 ohm speaker using NAD 2200 PEs back in the day. The NAD doubles in wpc output with 4 ohm speaker thus the volume control was kept lower to achieve the same volume as the 8 ohm speaker.
  • dekuda
    dekuda Posts: 756
    Has anybody here used the LSiF/X surrounds with RTI front/center speakers? I know that they are not matched with them but I was wondering how it would sound. I am looking at upgrading my surrounds and may have a chance to buy some LSIF/X. Also, can you run these surrounds off a AVR powering just a CSI5 which is 8 ohm? I have a Marantz SR7002 powering just my center and surrounds which are 8 ohm. Would running a 8 ohm center with 4 ohm surrounds cause any problem with my receiver? Thanks!
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
