What's wrong with this picture?
nguyendot
nguyendot Posts: 3,594
edited November 2010 in Speakers
http://portland.craigslist.org/clc/ele/2066844637.html
no affil...but look at the hookup of the sub :)
Main Surround -
Post edited by nguyendot on
  • AudioGenics
    AudioGenics Posts: 2,567
    I give up...
    what's wrong ?
    i can't make out the connections since there is no detail in the image.
    but if the seller just wanted to capture a picture of the back of the unit or 2 units
    it looks decent. Does not necessarily need to be a complete working connection
    EndersShadow Posts: 17,715
    I believe he is using both the line in RCA's and also the LFE in...a no-no from my limited understanding
  • AudioGenics
    but you only see one end of the connection ?
    I cannot see what is on the other end ?
  • ben62670
    ben62670 Posts: 15,969
    You get the cookie.
    Ben
  • nguyendot
    Come on people. You aren't supposed to use speaker level connections and LFE at the same time. Those aren't RCA's since there are EIGHT of them.
    Main Surround -
  • inspiredsports
    inspiredsports Posts: 5,502
    nguyendot wrote: »
    So buy it and rescue it from this horrible seller, and then you can do a genius textbook job of hooking it up :rolleyes:
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • nguyendot
    I want to but the shipping on that sub would kill it, lol.
    Main Surround -
  • AudioGenics
    http://www.polkaudio.com/downloads/manuals/home/PSW650manual.pdf
    see diagram 5
    The “high pass crossover” switch
    (Figure 5) on the PSW650 gives you
    the option of filtering bass from your
    main front speakers for the purpose
    of increasing power handling and
    lowering distortion at high volume
    levels.
    see diagram 8
    If the subwoofer output jack is filtered,
    we suggest using hook up OPTION #1
    or #2. If it is unfiltered, connect the
    subwoofer output jack to either of the
    line level “IN” jacks (Figure 8). With
    Dolby Digital systems, select subwoofer
    as “on” or “yes” in the “speaker set up”
    or “bass management” function of your
    electronics
    see diagram 10 (front speaker)
    This control adjusts the frequency range
    over which the subwoofer operates. This
    control only affects signals that are sent
    through the line level “IN” jacks and the
    speaker level inputs. It has no effect on
    signals fed into the LFE input.
    When
    using smaller main speakers, the upper
    range of the control will probably yield
    Please explain what is wrong again ?
  • nguyendot
    Whoa whoa.. you can do both speaker level and LFE on this sub simultaneously?
    Main Surround -
  • dorourke07
    dorourke07 Posts: 298
    I had directions with my sub on how to use both.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • AudioGenics
    hey... I suffer from the same syndrome
    ask for map directions ( i luv to cruise )
    read the instruction manual ( then whats a warranty for ?)
  • ben62670
    Both at the same time. I don't think so.
    Ben
  • AudioGenics
    but we don't know
    how the owner is actually using it in his system
    the actual application
    by way of just the picture....
  • cheif pontiac
    cheif pontiac Posts: 138
    there is a PSW 303 listed on E-bay where the guy has both speaker wire and line level input hooked up.
    http://cgi.ebay.com/POLK-AUDIO-PSW-303B-POWERED-SUBWOOFER-/110610603754?pt=Speakers_Subwoofers&hash=item19c0e7deea
    System:
    Samsung LN46C630
    Receiver: Yamaha RX-V1
    DVD/Blu: Denon 2910/Playstation 3
    Front mains: RT16
    Front presence: F/X 500i
    Center: CS400
    Rear surrounds: RT1000p
    Rear center: RT7
    Subwoofer: PSW505 X 2
    Marantz 2252B
    Technics SL-Q2 turntable
    Kef Q50
  • evil ryu
    evil ryu Posts: 41
