Signal Cable??? What to Expect????
rdb2001
rdb2001 Posts: 791
I just purchased all new interconnects, speaker cables, and sub cables from signal cable and Frank was really helpful and great to deal with. What should I expect when I hooked them up. I am currently using dayton audio terminated speaker cables, IC's, and sub cables. Is this an upgrade? Should I expect good results? This is the most I have ever paid for cables and hope it is money well spent and not a sideways move over what I have now.
Post edited by rdb2001 on
  • kevhed72
    kevhed72 Posts: 5,139
    edited November 2010
    Which model of cables did you purchase....Analog 2 or Silver....
  • rdb2001
    rdb2001 Posts: 791
    I ordered the ultra speaker cables and the HT analog two interconnects along with the sub cables.
  • zingo
    zingo Posts: 11,258
    What is your equipment and speakers? With equipment that has enough resolution, you should be able to hear an improvement in sound quality. At least though you know you will not have to upgrade your cabling for a long time to come...
  • rdb2001
    rdb2001 Posts: 791
    zingo wrote: »
    All my music is ripped in Apple Loseless. Looking for a DAC for my apple TV. Sounds Really good now, just curious to how much better it will be with the new cables.
    Fronts - Martin Logan Prefaces
    Center - Dual Martin Logan Encore TF's
    Surrounds - Martin Logan Motion 4's
    Subs - Dual Epik Legends
    Amps- B&K Reference 7250 and 2220
    Sources - Apple TV 160gb (looking for DAC for this)- ps3 - Sony BDP1000ES Bluray Player
  • resperc
    resperc Posts: 41
    I did a similar thing a couple of years back. I ordered interconnects, speaker cables and power cables and installed them all at once. Because I installed them at the same time I have no idea how each product enhanced the system, but I immediately noticed a "blacker" background and greater resolution of detail. Bass extension and pitch were also increased. I have a Polk Lsi speakers and Rotel electronics.
