Best way to remove vinyl lamination
AudioGenics
AudioGenics Posts: 2,567
edited November 2010 in The Clubhouse
what is the best ( and easiest ) way to remove vinyl lamination
refinishing speaker cabinets.
Post edited by AudioGenics on
  • messiah
    messiah Posts: 1,790
    A heat gun.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • ben62670
    ben62670 Posts: 15,969
    messiah wrote: »
    A heat gun.
    Yep and a flexible thin blade putty knife.
    Ben
    F1nut Posts: 51,766
    messiah wrote: »
    A heat gun.
    Exactly.
    Heat up a corner by waving the gun back and forth. Do not get the gun too close. In short order the vinyl will soften, then get a grip and pull it back with your fingers. Heat a little more, pull it back, repeat until done. Use caution as the vinyl will be hot. I recommend gloves. I don't like to use a putty knife as it can tear the vinyl and also scuff/gouge the particleboard.
  • fatpiggy
    fatpiggy Posts: 205
    Yep , heat gun.You could even get away with a hair dryier.I used a craft heat gun a tiny little heat gun used in card making the missus has.I just stripped my RT 12's. Comes off easy start at a corner heat in front of a section and peel as you go.I didnt use gloves but it does get hot.Dont use a knife as mentioned you will damage the MDF as its very soft and will scratch..For pieces that are hard to lift heat and use a razor blade to lift the edge carefully.
    What are you going to do with your boxes once you take off the old vinyl.
    Fatpiggy
