Ques. for Rti70 Owners...
Early B.
Early B. Posts: 7,900
edited January 2004 in Speakers
What has been your experience with placement? Since the power port is on the bottom, do you still move them away from the wall?
How far are the towers from your listening position?
"God grooves with tubes."
Post edited by Early B. on
    VR3 Posts: 29,427
    edited January 2004
    Towers are right up on the wall, and about 7-8 foot from listening position. Rock on! PC EZ!
    - Sid
  • DarrenS
    DarrenS Posts: 9
    edited January 2004
    Mine are on both sides of my bigscreen and sound great there, no need to worrie about bass from RTi70s I have a Shiva EBS 250w sub that rocks my house, If you dont have a sub you gotta get one and set those RTIs to small they sound alot better that way.
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2004
    Here's a cut and paste from the Polk Audio Home Theater Hand Book that may help with placement questions and help you get better sound from your gear.
    Since the left and right front channels are
    responsible for bringing music as well as
    movies to life, the “stereo pair” requires the
    most careful setup. For best performance,
    the speakers should be placed at least two
    feet from room boundaries, such as large
    pieces of furniture, walls and especially corners
    (Fig. 13). Placing a speaker closer to
    room boundaries increases bass, but may
    result in a “boomy” or bass-heavy sound
    and degradation of stereo imaging. Try varying
    the speakers’ distance from the rear
    walls, side walls, and corners until the best
    balance between low frequency extension
    and clarity is achieved. If your system has a
    subwoofer, chose a main speaker placement
    that provides the best imaging and most
    natural midrange balance, usually far from
    room boundaries. If you cannot get the
    speakers at least two feet from the room
    boundary, treat the adjacent room boundaries
    with absorbing or diffusing material
    (refer back to the section on Room
    Treatment, page 35).
    Avoid symmetrical placement. A speakers’
    distance from the front wall should not be
    within 33% of the distance from the side
    walls. For example, if the speakers are 24"
    from the side walls, place them at least 32"
    from the front wall.
    Place the main speakers at least a few inches
    in front of the front of your TV. Unless a
    large projection screen monopolizes your
    wall, don’t place the speakers too close to the
    sides of your television, as such placement
    constricts the width of the stereo soundstage.
    Small satellite speakers are designed to
    provide good sound when placed on a wall
    and often come with wall mounting brackets.
    But, as with other types of speakers, you
    should avoid placing the satellites within
    two feet of side walls. Since wall mounting
    satellites precludes placing them in front of
    the TV screen, place wall mounted satellites
    higher than the top of the TV (Fig. 14).
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2004
    if you have to stick them in or close to corners, like i do, then toeing them in will help. this means that you angle the speaker towards your listening position.
    you might want to look at peoples setups in the system showcase to give you some ideas or to just see what other people did.
    good luck
  • Early B.
    edited January 2004
    I was just wondering how other folks with the Rti70 dealt with placement. My limitations of speaker placement are aesthetics and WAF. If I move the speakers two feet from the wall, they will overwhelm the den (no dedicated home theater room yet). Since I prefer not to move the speakers every time I watch a movie or listen to music, I was hoping I wouldn't lose too much sound integrity by leaving the speakers against the wall.
  • Airplay355
    edited January 2004
    if you want to know what you will be missing then watch a movie or listen to music with the speakers against the wall, then watch the same movie or listen to the sae song with the speakers 2 feet away from the wall. if you dont notice a difference then dont worry about it. if you do notice a difference then you may have to compromise and settle for 1 foot away from the wall, or 6 inches away from the wall.
    my mains are about 2.5 feet away from the wall and are toed in towards the back wall. heres pictures of it will help http://clubpolk.polkaudio.com/showcase/view.php?userid=38451
    if you have pictures of your system, post them, it will help us help you
  • Grimster74
    Grimster74 Posts: 2,577
    edited January 2004
    Here are some pics of how mine are setup.
    http://clubpolk.polkaudio.com/showcase/view.php?userid=40818
