Jumper Strips on LSi25's
  • Osarion
    Osarion Posts: 188
    edited November 2010
    You attach them to any chasis screw nearby on the speaker and on the receiver.
  • pmckeealaska
    pmckeealaska Posts: 808
    Yea, I figured that. I'm just not too keen on unscrewing things on my components. Call me paranoid......
    Music and Movie Rig
    Samsung 40" HDTV 1080p
    LSi25 Front Speakers
    LSiC Center Channel
    LSiFX Surrounds
    Rotel RB 1080 2-Channel Amp
    NAD T763 Reciever
    Denon DVD 2900 Universal Player
    Audiosource 10 Band Digital Equalizer
    Audioquest CV-8 speaker cables
    Audioquest Sub-X subwoofer cables
    Audioquest King Cobra Interconnects
    Monster AVS 2000 Voltage Stabilizer
    Playstation 3 120GB Slim
  • pmckeealaska
    The following is from Club Polks "subwoofer setup" section:
    In the receiver's speaker configuration menu, we prefer to set the front speakers to "small", even if you are using larger floorstanding speakers. There are a few reasons for this:
    1) The subwoofer is specifically designed to reproduce bass. This frees up the main speakers to work on the highs and the mids. The entire system is able to play louder as well as cleaner.
    2) If the main speakers are producing bass at the same time as the subwoofer, at some points the bass will reinforce each other. At other points the bass will be cancelled. Allowing only the subwoofer to reproduce bass will yield a smoother response throughout the entire room.
    3) In most instances, setting the main speakers to "small" will allow the subwoofer output to remain operational when the receiver is in 2 channel (stereo or direct) mode. If the subwoofer turns off if you put the system in 2 channel mode, an alternative hook up method may need to be used. If so, please contact our Technical Support department below.
    So...am I missing something here? Should I be setting my LSi25's to "small"? I have always had them set to "large" and had no issues....thoughts?
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
    heiney9 Posts: 25,408
    CivicDude wrote: »
    It has been said. Loud does NOT equal quality. For example I have some in ear headphones that are loud -- but they sound terrible. They bass response is way off and the midrange is very mediocre at best.
    Die Spammer.............you've posted the same link in every thread you posted in and it has nothing to do with any thread
    reported.
    have a nice day
  • pmckeealaska
    I thought thats what that reply might have been. I dont understand these people. They need to get a life. Plus, it has zero to do with my last post. Just trying to annoy people I guess.
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
