Velodyne SMS-1 users
leroyjr1
leroyjr1 Posts: 8,785
edited November 2010 in Electronics
Does EQ'ing your sub really help and is it worth the money.? Was looking at the SMS-1 system but wanted some owners input on the system.
Post edited by leroyjr1 on
  • math wizard
    math wizard Posts: 106
    I don't own an SMS-1, but I'm EQ'ing my sub during 2.1 channel listening by running it through my AVR and using Audyssey. Everything else is run directly through my pre-amp to my amps unEQ'ed. EQ'ing the sub makes a big difference. I'm looking at buying a SMS-1 or something similar now.
    When in 5.1 mode, everything is EQ'd.
    Processor - Emotiva UMC-200
    Pre-Amp (2 Ch) - Emotiva USP-1
    DSP Minidsp nanoAVR DL
    DAC (2 Ch) - Emotiva XDA-2
    Amp (Fronts) - Emotiva XPA-2
    Amp (Center/Surrounds) - Emotiva XPA-3
    CD - Emotiva ERC-1
    Fronts - Polk Audio RTi 12
    Center - Polk Audio CSi5
    Rears - Polk Audio RTiA1
    Sub - Epik Knight
    Sub EQ - Velodyne SMS-1
    Monitor - Sony XBR65X850C
    Blu-Ray - OPPO BDP-203
    Network Media Player - Chromecast Ultra
    Power Conditioner - APC H15
    Power Conditioner - Emotiva CMX-2
    PVR - DirecTV C61k
    Remote - Harmony Touch w/Hub
  • dorokusai
    dorokusai Posts: 25,576
    I use the SVS version, which according to TomV is much better and it certainly helped my subwoofer quite a bit. I have since sold the subwoofer but will use it on the next since it doesn't matter what you use it on.
  • danz1906
    danz1906 Posts: 5,144
    dorokusai wrote: »
    Did you use it with a SVS subwoofer? I'm thinking of getting one for my
    SVS ultra-13. What did it do????
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • dorokusai
    www.svsound.com and yes.
  • 98Badger
    98Badger Posts: 317
    I use the SMS-1 for my HT and it is definately worth it for me. My HT sub is a DIY using a 15" audiopulse driver. I find I increased the sub volume after eq'ing because it was very clean. If you get one, don't mistake clean base for less bass. The SMS is also very easy to set up. I'd also say the manual setup does a considerably better job than the auto setup (which is good in it's own right).
  • leroyjr1
    Thanks everyone.
  • jinjuku
    jinjuku Posts: 1,523
    I'm using the Behringer DCX2496 and REW (Room EQ Wizard) with the Behringer ECM8000 measurement mic.
    It is more work than the SMS-1 but the upside is it does more and costs less.
    And yes EQ'ing your sub will make a difference.
  • leroyjr1
    Does anyone have one for sale?
  • w_coyote
    w_coyote Posts: 66
    I think I saw one on audiogon today. I didn't look at it just saw it listed. I think it was $325.00.
  • Sherardp
    Sherardp Posts: 8,038
    Check AVS or Audiogon. I've seen some good prices there.
    http://cgis.audiogon.com/cgi-bin/srch_fs.pl?searchstring=sms-1
  • leroyjr1
    Sherardp wrote: »
    Yeah, seen both and was thinking about the one for $325 but he has zero feedback. Also there's one local to me that posted yesterday on Craigslist. Sent the seller 4 emails without any response.
  • PSOVLSK
    PSOVLSK Posts: 5,382
    I might sell mine. Let me think about it.
  • PSOVLSK
    Sent you a pm Leroy.
