MONITOR 70 QUESTION; max wattage/rms/bi-amp/ 7.2 OR 9.2
TOOdamnFRANK
TOOdamnFRANK Posts: 32
edited November 2010 in Speakers
I just purchased a 9.2 Receiver (135w/channel) and am considering bi-amping my Monitor 70's, but here is my concern. According to what I have read on the Polk Audio website Monitor 70 Speakers have a "Recommended Amplifier Power" of 20 - 275 w/channel.
My main question is this; is the power listed above the recommended maximum wattage for the Monitor 70's or their RMS??? :confused:
I currently have a 135watts running to them and if I bi-amp them I would obviously be pushing 270watts RMS into them (theoretically). Would this be too much? (I have everything currently crossed over at 80Hz)
Does anyone know the maximum wattage that the Monitor 70's can handle RMS and/or overall?
sub question - If I bi-amp the monitor 70's how much of a difference in sound quality should I normally expect??? (is it worth the effort vs something like adding another set of speakers)
Please only reply if you honestly know, I would hate to run 270 watts RMS into my $500 speakers and have them ruined. :frown:
MY VERY FIRST 7.1 SURROUND SOUND SETUP;
FRONT - Monitor 70
SIDE - Polk Monitor 60
REAR - Polk Monitor 60
CENTER - Polk CS2
SUBWOOFER - Polk PSW505 12" (soon to be upgraded)
RECEIVER - Onkyo 808
CONSOLE - PS3 Slim / Wii
TELEVISION - Philips 52" HDTV
OTHER - Custom Gaming PC / Custom HTPC / Gemini iTT SE Professional Turntable w/ Sony MDR-V6's, ...
Post edited by TOOdamnFRANK on
    EndersShadow Posts: 17,707
    What you are considering doing will not blow the speakers, however most folks dont normally call that bi-amping. Bi-amping is using two seperate amps, one for highs one for lows. This way you have two different powersupplys driving each channel.
    What you are talking about is still using the same powersupply so its not "technically" bi-amping. Its more of a marketing take on the word used to sell recievers.
    Regarding how much wattage your sending to the speaker, regardless of if you have a 1000 watt amplifier or a 100 watt amplifier, it will only send the amount of power the speaker calls for based on whats playing. Also when you wire it like you will you wont actually be sending 135x2 to it, but something much much less.
    You have a much higher chance of running out of power before your Monitor 70's would fry unless your using a dedicate amp that has a higher power rating than your speakers.
    Will it sound different/better? Thats debatable but I had my Monitor 60's bi-amped like your talking about and when I moved I went back to just a single wire. I actually like the way it sounded with just one connection rather than two. But if you have the wire and want to give it a try it wont hurt. Will it sound better than adding a second set of speakers, IMHO No. Will you still need a sub: YES
  • kuntasensei
    kuntasensei Posts: 3,263
    If you're talking about bi-amping off of your Onkyo, you might as well not bother. All of the power from the Onkyos comes from the same power rail, pretty much negating any benefit you might get. In other words:
    1) Though it says 135w/ch, that's only with 2 channels driven. The all channels driven wattage of most Onkyos won't exceed about 65-70w.
    2) Bi-amping with the Onkyo AVR basically just channels the same amount of power to multiple locations, so you're neither going to risk sending the speaker too much power or gain any benefit from it.
    3) If you're crossing them over at 80Hz, it's rare in the average room for your speaker to require more than 65w anyway. In fact, even with near-reference listening, if you're letting a subwoofer handle the bass, the likely average of power used by a speaker as efficient as a Monitor 70 is around 30w.
    4) If you feel that the Monitor 70s are underpowered, the best option would be to get a 2-channel amp, at which point I would recommend trying the crossover in your AVR for the mains at 60Hz if you do any 2-channel listening. Otherwise, they're fine at 80Hz... especially if you upgrade to a better subwoofer like your sig says.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    ES and Kuntasensei are right...in fact you will not get any more power than what you would get for one channel by bi-amping off that Onkyo...In other words the best you can hope for is 135 watts/channel regradless of how you wire them. The wattage in this kind of setup is NOT additive. For that you would need either two different amps, or two separate power supplies in one receiver.
    Also, the Onkyo TX-808 cannot really put out a true 135 watts in 7.1 or 9.2 surround. Your real wattage will be half that or near that number. I have an Onkyo TX-SR 805 and my unit can actually put out a true 130 watts to a 5.1 system--maybe even exceed that wattage. But the 805 has a transformer the size of the Onkyo 1007/8 series and weighs about 51 pounds. The 808 is a great AVR but its insides have been scaled down from the 805 which ruled the power roost for the Onkyo 800 series.
    In any case, even if you had a power amp that was rated 300 watts/channel you wouldn't blow the M-70s from too much power. The problem is too little clean power--that causes the amp to clip and fry your speakers.
    Enjoy!
    cnh
  • Lietuvis91
    Lietuvis91 Posts: 909
    I hear and read so many poeple saying that bi-amping is a waste of time, but I will have to go against the grain here and from my personal experience say that it DOES work. The difference is not collosal by any measure, but ask me which I prefer?!
    I have the m70's in my 2ch system bi-amped. I got my arse chewed out on audioholics forum for saying that I heard a difference when there supposedly was non, so I set my speakers back to regular wiring for a few weeks. Then I switched them back to bi-amped. And I don't know what to say, other than, the highs are crisper and clearer and the bass is tighter and deeper.
    I suppose not all receivers are setup the same, so most receivers may not privide any more total power to the speaker. But in my case the sr7002 has "discrete" amps and I think because power in each channel does not drop off when you connect more speakers, the channels can be doubled up to feed more power to one speaker.
    I mean, lets think about this: Marantz designed the receiver with bi-amp capability, even built in a physical switch on the back to enable this function. Polk desinged their speakers to be bi-amp capable. I really don't think manufacturers would spend the effort to build these functions into their products, if they really were completely useless. That doesn't make sense!
    I will not get into an argument here with anyone about this either. I hear what I hear, you can't prove otherwise to me through a post on a forum. So for what it's worth, I do believe that bi-amping works, but possibly not with all equipment.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
    Lietuvis91 wrote: »
    Glad you heard a difference! It may indeed be to the way your Marantz is setup. Not to knock Onkyo but Marantz is a bit higher end, so perhaps the components make the difference, I dont know. I know with my Integra 5.9 I didnt hear any difference, but like many things audio YMMV.
    To the OP, if your not planning on using the channels otherwise give it a go and make your own conclusions. As long as your happy with the way it sounds, thats all that matters.
    Audio is subjective and in this case its one area where that will be shown. So give it a go and make your own conclusions. It will only cost a little bit of speaker wire (a very small price).
  • kuntasensei
    Note: That's why I specified that was the case with the Onkyos in my post. With a Marantz, I don't doubt that there might be some benefit. Onkyos, on the other hand, (and especially with this year's line, which is gimped all the way up to the 1008 compared with the x07 series) have a tendency to be over-rated as far as what they can actually put out. But as I said before, the average room with efficient speakers will not require that much power, especially if the speakers are being crossed over at least a half-octave above their -3dB point anyway (and more so if you're crossing over a full octave above, as the OP is with his Monitor 70s). Bass is what requires the most power to drive, which is why dedicated subwoofers are your friend when it comes to most consumer-grade AVRs. They take the majority of the load off of the AVR and give it the headroom it needs to cleanly drive the mids and highs. I'm running a 9.1 system off of my Onkyo TX-NR1007 with all channels crossed at 70Hz to a SVS 20-39CS+ sub, and I don't feel that I'm underpowering any of the speakers on their own, even when my rig is cranked up half-past-ridiculous.
    But like ES said, all it costs you is some speaker cable to try it. If it works for you, great, even if there's a heapin' helpin' of placebo effect going on.
    Equipment list:
    Emotiva XPA-3 amp
  • TOOdamnFRANK
    cnh wrote: »
    Enjoy!
    cnh
    I Upgraded to the TX-3008 which is why I have all these new questions. But now I feel like it was a waste if I cant use my extra surround channel to add more power to my fronts. Damn marketing scams!!! I guess it's my fault for not learning more before jumping into this home theater stuff, I only just built my setup 3 months ago...
    As for the subwoofer comment someone made, I have a PSW505 right now, until my ED A5-350 (15") arrives in the mail... Loooooong wait so far, hoping it's worth it, because now I'm regretting it with the new HSU 15 that just came out. I hate the look of the HSU but the stats look boss.
    FRONT - Monitor 70
    CENTER - Polk CS2
  • TOOdamnFRANK
    Should I return my Onkyo 3008 for the TX-5008??? Would this allow me to combine the sorround chanels with my front channel to double the wattage, or is this impossible and it would just make two connections to the one speaker thus making no actual change to the rms wattage sent to the speaker? I figured sending two signals of power would double the power or at least increase it? I understand that you cant make the one amp output more power than it already does, but if it outputs say 65watts, in real use, under 9.1 wouldn't taking one of those channels and adding it to the front add those extra 65 watts to the front channel in a 7.1 setup on the same receiver? or does this just provide another signal path and cut the extra power and divide it evenly among the existing 7 speakers or does it just not use the left over power at all???
    FRONT - Monitor 70
    CENTER - Polk CS2
  • Outfitter03
    Outfitter03 Posts: 563
    Not to be TOOdamnFrank but if you are worried about more power to your front speakers, buy a power amp to go along with your AVR. The AVR has the required Pre-outs. There is a nice Adcom 555 in the flea market on this site and it has the power to push your Monitor 70's to ear splitting levels. This will free up more power for the surrounds. 200Watts of pure, high current, power. You will notice a difference! Get decent interconnects and speaker cables and enjoy!
  • TOOdamnFRANK
    Sorry for all the question guys,but if my receiver is only outputting 140 w/channel, (or so it says for 2 channels), would I be better off downgrading my fronts to Monitor 60's and selling my Monitor 70's???
    Would replacing my front speakers with Monitor 60's sound better than the Monitor 70's I currently have, due to the lack of power coming from an Onkyo TX- 3008 / 5008 Receiver, because the M60's need less wattage????:frown::frown::frown:
    Another Question - Would I get more power to my speakers from running the wide surround channel and front channel outputs together to my front channel speakers or from leaving the wide surround channel unused with nothing plugged into those outputs??? (Would the extra power not being used to run a 9th channel vs 7 free up more wattage for my existing front speakers than running the wires directly to it???)
    FRONT - Monitor 70
    CENTER - Polk CS2
  • TOOdamnFRANK
    The problem is I am new to this and learning as I go. What external type of amp would I need exactly, aside from that used one listed? Would it be considered a "stereo amp" because I was worried a 2 channel amp wouldn't work since all together I have a 7.2 setup at the moment, or would the amp just power the fronts and the receiver would do the rest of the surrounds? Also would this change the overall sound vs the other speakers? Im worried about it not having the exact same frequency range as the receiver and missing out on some stuff, not sure if this makes sense, but once again im a noob, im a noob, im a noob, dont hate me for trying to learn even if my questions seem stupid. I like to learn every little thing that i can so bare with me.
    Do you think, in your opinion, it's worth the trouble to buy a 200-300 watt amp and run it to the monitor 70s in front with my crossover somewhere between 60-80Hz and running two 15" Subs, or would the difference be something that's not worth the extra money spent?
    sorry, but 'm a total newbie, like i said Ive only been researching and doing this for 3 months now, so any help or answers to these seemingly stupid questions would help me greatly...
    How exactly do I go about hooking an amp up to my receiver / surround setup? (pre-out on receiver to the amp, amp wires to the speakers Im guessing?)
    FRONT - Monitor 70
    CENTER - Polk CS2
  • kuntasensei
    The first question is... Why do you think you need more power to the Monitor 70s? Is there something about the sound that's making you think this, or are you just wanting to do it just to do it? Because I assure you that, while an external amp will probably do the trick, it is rare that your AVR will be asked to send more than 65w sustained to the mains in an average sized room. Most of the wattage requirements outside of that are for transient bursts, which the Onkyo can deliver as needed (see the Onkyo's dynamic power rating). Additionally, the surrounds require very little power as they don't receive nearly as much content. In fact, during movies with surround, your center channel will be the speaker that gets the most content - more so than even the mains.
    I think your best bet is to get that ED sub in place, run Audyssey's MultEQ setup (I can help you if you're curious on the best way to do that), then see how it sounds before you buy any other equipment. That subwoofer is going to make a massive difference in the sound of your rig, and I still say that your AVR is more than capable of powering the Monitor 70s if you're using a good subwoofer.
    So why do you think you need more power to the mains?
    Equipment list:
    Emotiva XPA-3 amp
    tonyb Posts: 33,072
    Your splitting hairs dude and worried about non essentials. Either receiver is more than enough for your Monitor 60 or 70 as they both are very easy to drive. Don't fret on the bi-amping off a receiver thing,not worth the time or effort. Just hook them up and go,your over thinking things that don't need to be at this point.
  • kuntasensei
    tonyb wrote: »
    A big +1 to that. Bi-amping from an Onkyo is like pouring the same amount of water through two pipes instead of one. Rationalize it all you want - you're still getting the same amount of water out the other side.
    Equipment list:
    Emotiva XPA-3 amp
  • TOOdamnFRANK
    I was worried I wasnt giving them enough power, but I guess not after the comments Im getting. Thanks for the advice guys, Ill just "leave well enough alone" as they say.
    FRONT - Monitor 70
    CENTER - Polk CS2
