Subwoofer vibration
theatre_man
I have a PSW-404, and it has a small vibration sounding noise if i listen right next to the speaker.......does anyone know what my problem is?....i have already had to replace the driver, because it fried.
Also.....The sub has a hum, that you can hear when everything is off, and it has a split wire subwoofer kit by IXOS. Someone else had a similar problem and they returned their sub and got it replaced.....could this be what i need to do....possibly upgrade to 505?
I dont know what to do
My Setup:
Toshiba Theaterwide 51H83 HDTV
Yamaha RX-V3300 reciever
Yamaha CDC-585 cd
Sony Progressive Scan dvd
Wharfedale Evo-30 mains
Wharfedale WH-2 side/rear surround
Wharfedale Evo-Centre center
Polk PSW-404 sub
IXOS speaker wire and cables
Yamaha CDC-585 cd
Polk PSW-404 sub
Post edited by theatre_man on
Hum - Transformer noise within the sub
the vibration, unless you driver is spatting it out audibly at 1-2-3 feet (fwiw, your seating position) dont worry about it.
My M&K makes a 'vibration' noise too......so dont sweat it. Also you could possibly be pushing it to hard.
Also, my M&K has a very audible HUM when the volume knob goes past a certain point. FWIW- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Make sure your sub volume knob isn't turned up past the 12-1 o'clock position.
I had a similar vibration like sound from my psw150 but didn't have a humm associated with it. Mine sounded more like paper vibrating in a strong wind. I took it to an authorized polk repair specialist who reglued the "spider". Problem fixed.
Mully
Sony STR-DA5000ES
RT12
M3
PSW150
Klipsch Center and rear/back surrounds
35" Sony XBR CRTSincerely,
Mully
Sony STR-DA5000ES
Polk RT12
Polk PSW150
Polk M3 surrounds
crappy Klipsch center soon to be replaced by CSi30
