cabinet for 95 civic coupe
i have a pair of mm2124's that i want to build a sealed cabinet for.i know spec's say .88 for each.does this include polyfill ?if so,how much?i have a rockford power 500 to push these so wattage is plentyful.i listen mostly to rock and want kick more so than boom.bass slap and electronic keyboard bass more so than majic mike.i am willing to give up a little spl for more gut impact and deep bass throw.will building the cabinet a little larger do this?say 1.0 cuft.i can go as wide in my trunk as 32 in. and 16in heigth.depth is variable.i have .75 mdf and i want to put a center divider in to seperate the woofers and double as a brace.i'm looking for some HxWxD dimentions better than the polk page gives.customer service suggestions or anyone with same car/equipment exp.
Post edited by rehall on
Take that into consideration. Adding polyfill will help slow down soundwaves and help make the sub sound as if it were in a slightly bigger box.
I've heard MM's and even in a sealed enclosure, you won't be giving up too much SPL. I prefer SQ over SPL (not the only one around here
With that, it shouldn't be hard figuring out box dimensions. All depends how custom you wish to make it.
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
if i did go with .88,how much polyfill should i use?half a pound?one pound?how much will it take to allow for woofer/magnet and divider volume?polk shows dual cabinet dimensions for everything but sealed.as far as coming up with measurements.is taking away an inch from width and adding it to depth going to give me the same internal volume?help!
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
