Audio Cable choice, Receiver Choice
boringjay
Hi everyone, I am new to this forum and new to hifi family. I purchase two polk audio monitor 70 on newegg. My questions is do the speakers come with cables? if not what kind of cable should I get.
Also, I need a receiver, so which receiver is good within 300-500 price range. I was looking at ONKYO TX-SR608 for 370
OR there is better choice.
I use these speakers mainly for listening to classic music
Do I need to get a better CD player?
Thanks for everyone's help. Hope I can find some solutions here
Post edited by boringjay on
Welcome to CP.
SPeaker cables are not included.
BlueJeanscables is a good starting point or signalcable.
For AVR you will get a lot of recommendations to get one with preouts to power and external amp for better amplification to your mains. May not do it now but the audio journey will lead you there. In your price range most likely a Yamaha.
What CD player do you have?Speakers: SDA-1C (most all the goodies)
Welcome to CP.
Thank you
Any website that sells these cables? Which type of cable should I get?
If I do not get an AVR now, I wouldn't be able to use the speakers. Right?
So far, I will stick with these two speakers, and maybe next month I will get a polk audio CS2, but the thing bothers me is which AVR should I get there are so many choices.
I look at newegg ratings, and ONKYO TX-SR608 seems like have a very good rating.
I have a cheap DVD player now, which plays CDs, but I think many AVR can play music from an IPOD right? -
Welcome to Polk forum.
2 sources for speaker cables (good to get started and you can upgrade later):
http://www.bluejeanscable.com/store/speaker/
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
Go 16AWG or thicker (smaller gauge number) and terminate with banana plugs if applicable or desired.
Enjoy your speakers and the start of a wonderful audio journey. -
Thanks, everyone! any more suggestions on AVR and CD player?
For just a touch over 500, you might consider the Onkyo tx-nr708 and the Yamaha RX-V1900. I have listened to both and like them. I currently own the Yamaha 1900. Newegg has both at good prices.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4 -
I would recommend a Harmon Kardon 240-watt Stereo Receiver, model no. HK-3490, many times available from Amazon or JR for $300 shipped.
For cables the Belden 500 series cable Blue Jeans has or the MonoPrice equivalent would be great choices....12 or 14GA would be good for most runs.
For a source look for a CD/DVD Player that supports SACD and you will be in for some great Classical listening.SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
Thanks everyone! I will look through these receivers, but I really don't know which one is a good choice for me. Any ways that can define a receiver that fits my need?
I love your Onkyo choice and would suggest stepping up into a better, and equally modestly priced cable from Signal Cable.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
anymore recommendations on receivers?
how is Denon avr 1911 sound like? good?
I will use the speakers mainly for listening to music
is this better than ONKYO TX-SR608
and I can get the Denon avr 1911 for 400 dollars in NY -
I have the older version of the Onkyo that your looking into, the 607, love it, but I don't have pre outs, which now I have to go back, upgrade my AVR and then buy a pre amp. With that being said, I'd make you a good deal on the 607, which is great. Good luck, welcome to Club Polk.
I would also suggest the Onkyo TX-NR708. I have an 808 and am really happy with it. The network features are kind of cool. We used ours briefly as a pre-amp and the music streaming was a big hit.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
Welcome to CP.
As far as speaker wire go with 12-16 guage. i would go with everyone elses advice about getting a receiver that has preouts for an amp because eventually your gonna want more power
. The 7xx series onkyo will suit your needs. You can probably find a nice used you for a great price. Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
seems like Denon AVR 1911 has a Pre-amp Outputs, plus I can get a new one for $399. and I did some reseach, Cnet reviews says it has better sound quality. Does anyone have used this receiver before?
wait, it only has preamp output sub
as a final decision
I decided to purchase Yamaha RX-V667
what do you guys think? -
I'm not a Yamaha fan but if you felt it met your needs, than its the right unit.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dargman69 reported"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
