Amp confusion
King J
my setup consists of -rti10's, csi5, fxi3, & psw 505. onkyo 905 as my avr. now im looking into seperate amps & ran into a problem. im looking at an Emotiva xpa5 & xpa3. is this going to be too much power??? i want to use the xpa5 for the low input on the 10's & center & surrounds, then use the xpa3 on the high input on the 10's & center. now is this too much or should i just power everything with just the xpa5 & be happy. comments and input are greatly appreciated. thanx
Post edited by King J on
Power everything with a 5-channel amp and let that sound settle in on you for a while. Read up on bi-amping, so you can make a well-informed decision on it later. Personally, I think it's unnecessary, and in your case (gear very similar to mine), the difference/improvement will be negligible. Enjoy!
I would recommend you begin with an Odyssey or NAD two channel amplifier and let your receiver power the rest of your speakers.
The Emotiva are bright your treble will sound as if it is simply on top of what ever you are listening to not a part of it. Those particular Polk speakers rti10 are already forward sounding enough.
RT1 -
I think in that setup, running the XPA-5 will be plenty. No reason to BIAMP those IMHO. The XPA-5 is a good budget amp and it is at a decent price right now. Have you considered used amplification at all? There are many good deals on used amps that I think would outperform the XPA-5...
The other thing you have to remember is that RTi's are inherently bright, and Emotiva amps tend to be bright, so it can be a rough combo...
Ooops.... Beat me to it RT1!
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
dcmartinpc wrote: »I think in that setup, running the XPA-5 will be plenty. No reason to BIAMP those IMHO. The XPA-5 is a good budget amp and it is at a decent price right now. Have you considered used amplification at all? There are many good deals on used amps that I think would outperform the XPA-5...
Don
RTi's are not bright....they have sparkle! :biggrin:
Even an older B&K would work nicely.HT SYSTEM-
lsi 9's -
There is no such thing as too much power. Your ears will give out before the speakers do. So amp up and enjoy. Welcome to Club Polk.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
RTi's and Emotiva can be a very forward and bright sounding presentation. Perhaps good for HT but definitely not for music if you are looking to get the best possible enjoyment for extended listening sessions.
thanks for all of the input. its 90% ht & 10% music. one last question/option though, would an xpa2 on the towers & the xpa3 on the centers & surrounds be cool or should i just stick with the xpa3 for the fronts and call it a day?
I'd get either the 2 channel or the 3 channel. You don't need both with that setup. Personally I'd pass on the Emo (I have owned one), but I do understand the price is right on those things plus you get a warranty, etc.
If you intend to upgrade your speakers in the future then maybe the 2+3 or the 5 channel amps make sense.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
That or a Parasound will tame the highs somewhat.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
That's exactly what I had. It was not worth the money. A 5-channel will do the same for far less. I scaled back to what I have now without diminishing performance, and had some extra cash to spend on other toys.
Still don't get why a person would use an amp to correct a few $$ in parts problem when it comes to the RTi line up (for music listening).
Pad down the tweeter with a different resistor to tame the high's. As I understand the Polk line up the RTi's are Polks top speaker really meant for HT so they would understandably be designed with an aggressive top end. The LSi's are more the musical.
When I built my ZDT3.5's I made sure to have 2 extra resistors for the tweeter circuit that were above and below the median value. This allowed me to tweak if I found the top end either to aggressive or rolled off too much. -
I would go with a 2 channel amp and a 3 channel amp. But I also listen to alot of music. I personally went with a seperate 2 channel amp for my fronts and a 5 channel amp for everything else. For my system there was a noticeble difference when I added a 2 channel amp to the 5 channel. The 2 channel amp has more omph, more kick, more detail, more everything. Both of these amps are from the same B & K reference line with just about the same watts per channel. So I would do a 2 and a 3 or 5 channel amp. To me there is a difference. YMMV
b&k 200.5 or 200.7 is my choice. you get them for decent price in Used market.
