lexicon 412
erniejade
i am looking at one locally. I have never heard one before. From what the seller is saying it is the same as a bryston 8 Best. I would use it in 2 ch. mode and do not have a need to the 4 ch mode. ( unless i put 2 to the highs and 2 to the lows on the Sada's.)
I have heard good things about it but never heard one. Anyone have any experience with this amp?
Looking for a replacement for my McINtosh 2105.
Post edited by erniejade on
Yes it is identical internally to a Bryston 8ST,which is basically two 3B's in one chassis. I have a 3B.
btw.you will not be able to use it in 2 channel(bridged mode)with SDA's. -
really? cant take the load or true mono design?
I could run it in 4 ch and go to the highs and lows yes?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Bridging will make it non common ground which would make it incompatable with SDA's.really? cant take the load or true mono design?
Sure if the speakers have two sets of binding posts.I could run it in 4 ch and go to the highs and lows yes?
