CSi A4 or CSi 3/5 ok with RTi A7?
Just got some RTi A7's, which replaced my Sony SS-MF550H. Currently still using a Polk RM6752 as the center channel, but planning to upgrade that next, either before or after a new sub (which is another story).
I don't really want anything too massive, so was wondering if either the CSi A4 and CSi3 would work. The kick stand on the CSi5 is kind of attractive, too, since I have a rear projection.
"No matter where you go, there you are."
60" SXRD / Denon 4306 / Polk RTI A7 / PS3 / 360
Post edited by Uxi on
All will work fine. The csi a6 would be my choice if size wasn't a issue.
+1 for the CSi A6. I just recently upgraded RTi70's to the RTi A7's, and followed that with the A6 replacing our trusty CSi40...
Go big or go home!
Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
CSi3, CSi5 and CSia6 are all nice. i have all 3 of them
i have a CSi3 up for grabs, but if you can. get a CSia6.mole' -
I did what mak99 did so +1 for the CSi A6. If you are space constrained though, the CSi A4 is by no means a slouch. I listened to it in the store and it sounded good too - just less bottom end.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
WELCOME TO CLUB POLK!!
I concur with PrazVT above. And would add, at least now you're actually hearing some clean highs and mids after dumping the Sonys? Much better, tighter low end as well!
Enjoy your POLKS!
