Holy moly!
Jstas
Expert Moron Extraordinaire
Post edited by Jstas on
And some MM3000's
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3069796917&category=14943
Put those together with those 4x6"s and the 10 inch subs and you'd have a pretty nice setup! Not super loud and powerful but very clean and accurate.Expert Moron Extraordinaire
Polk dB3055 5.25" Component set
Add teh dB10 from above and that would make a nice basic stereo, a very good starter system with a decent 4 channel wired in 3 way operation.Expert Moron Extraordinaire
Polk MM3065 Component set
Add these to those MM3055's and a dB10 or make two seperate 3 way systems with the dB's pictured above.Expert Moron Extraordinaire
Those 6510's are interesting. The basket, magnet, dustcap - looks almost, if not identical to the 65 series drivers used in the Monitor/ RTA / SDA home speakers.
Cheers,
Cheers,
Russ
They are identical just beefed up. They have layered baskets that Polk called teh Casket Basket and they are virtually resonance free. The surrounds are a tad heavier to stand up to the elements better. I believe that the spider is treated with a chemical to improve its resistance to water. Overall though, they are the same Dynamic Balance speakers found in the home audio speakers. Hence the reason they are considered Polk Audio's best example of what they can do for car audio. They are also the only speaker company to use thier home audio technology in thier car audio gear.
I have the dB3065 component set up front and the dB6510 seperates in the rear in my truck with a 10 inch dB10 sub powered by 1200 watts of Kenwood eXcelon power.Expert Moron Extraordinaire
can monster XP home speaker wire be used for the car?
-Cody -
You can use whatever wire you want. Personally, I would not use it. I'd go with StreetWires wire. It's fairly inexpensive and good quality wire. It also stands up to the weather and elements.Expert Moron Extraordinaire
do any chain stores sell SW?
i saw monster at best buy and circuit city, but only home wire, i didnt know if you could use home wire though b/c of noise/has to stand up to more elements
-Cody -
Well, speaker wire is speaker wire. The difference between home and car is in the insulation. Car wire has urethane/polypropelene jacketing that doesn't get brittle, doesn't crack and stands up to weather and car grease and other crap.Expert Moron Extraordinaire
I jsut wanna find myself two new goddamn tweeters that'll sounds good with my setup...
and be dirt cheap too...
see how easy i am to please?Testing
Testing
Testing -
i wish i had two of the same tweeters...
for dirt cheap
im easily pleased too!
-Cody -
haha -- u want the other one? it was cuttin in and out on me and sounded a little "Weird".The Artist formerly known as PoweredByDodge
lol...
ok, lemme rephrase that
i wish i had two of the same momo tweeters
for dirt cheap
-Cody
