What's the (best sounding) High Resolution Speakers You've Heard?
What are you powering those Carver Ribbons with? I think that has just as much if not more to do with the speed and response of your system. If there incoming signal is laid back it doesn't matter what speakers you use.
Altec Voice of the Theatre A5 cabinets topped with 1505 horns and AlNiCo 288 drivers are at or near the top of my list. Sound you could climb inside of.
I know of another slightly domesticated theatre horn system using RCA field coil drivers in RCA "Ubangi" horns which probably surpass the aforementioned A5 - but I am sworn to secrecy :-) -
The surface area of a panel and its dispersion angle are critical.
RT1 -
B&W 800D's. this was a few years ago so I have no memory of what the source or amplifiers were, but the cables looked like garden hoses. sounded like the orchestra was in the room, complete with chairs creaking and players smacking their lips. blew my mind.Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
wow, finally got to 100!Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
Actually one of the more accurate speakers I heard back in the day was the Apogee Acoustics Mini Grand speakers. They were similar in ideology to Carver but smaller in footprint. Extremely hard to run is what the sales guy said. He said they needed two amps and the ribbon was 1 ohm not the 4 ohm they normally were.
It increased sensitivity being 1 ohm. Not sure if I buy that but that is what he said.
I heard them with a Gold Faced B&K Amplifier and Preamp with a Rotel CD player. Sorry don't remember part #'s this is back in the early 90's.
I just remember hearing sounds in the music I never heard before. I just was to young and poor to own them. -
The problem Mega is the relatively high current required of the metallic element of the ribbon which results in higher mass and heat thereby diminishing the SQ. It is simply a given of a ribbon.
RT1 -
Huh?
I literally have no idea what you are talking about.
I dont' think surface area has anything to do with it. I KNOW that the Carver ribbon is capable of resolution on par with any speaker that I can think of including ESL's and Magnepans.
I think that my Quads are capable of being more transparent with greater high frequency air and extension (but lack the dynamics of the Carver)...but as far as resolving minute detail on the recording....I dunno about that one.
BDT
Ditto.What are you powering those Carver Ribbons with? I think that has just as much if not more to do with the speed and response of your system. If there incoming signal is laid back it doesn't matter what speakers you use.
Agree.reeltrouble1 wrote: »The problem Mega is the relatively high current required of the metallic element of the ribbon which results in higher mass and heat thereby diminishing the SQ. It is simply a given of a ribbon.
RT1
The ribbon isn't the culprit so much as the PASSIVE CROSSOVER~ ribbons are one of the fastest speaker designs on the planet. Horn are of course more efficient, but can get screechy.
I went active with my Carver AL-IIIs and the difference was....astounding. I'm calculating @ 40-50% of the power requirement was being dissipated as heat in the crossovers. Also, the clarity was MILES ahead.
The only speakers that might give me pause about Carver ribbons are the big SDAs....not sure about that; might have to keep a pair of each~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
The big SDA's are overrated._________________________________________________
bose, now that is high resolutionLiving Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
Do you consider the 3.1s one of the "big" SDAs? I always thought they were pretty quick.
stubbySRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2 -
Newform Research. R645 V3 (I own)
or the Line source reference.
triple stack ribbon tweeter. You want fast..;) I own a pair and I will say, they are awsome.
http://www.newformresearch.com/Most people just listen to music and watch movies. I EXPERIENCE them.
Sorry, I think I own version 1... They look the same.Most people just listen to music and watch movies. I EXPERIENCE them.
stubby
No, I don't consider them one of the big ones.
I'm just saying that there's too much of a following thinking the big boys are the holy grail of speakers. They are not._________________________________________________
I like the Vandy's 2's and 3's. They beat out many more expensive speakers.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
MMG's: $400
Wood Frame & Xover mods: $400 plus labor
Best sounding speakers I've heard: Priceless.
+1 Ricardo!! Mine aren't quite as pretty but I wouldn't trade 'em for 'nuttin! :cool:Aaron
Enabler Extraordinaire -
Ditto.
Agree.
you are incorrect. The metallic ribbons mass is a limiting problem by its design along with the heat, I realize nobody likes their baby called ugly but take it to the carver forum, we blow ours you can blow yours.
you dont have to like it
you dont have to agree
but it is the truth
I would agree the crossover is also a problem and active has its place, but a panel without it is the certainly better than either.
Fact is Matt Polk really disliked them, no??, well he told me so along with several others here, why, the sound was strained, I won't say I did not enjoy them, I did and had several pair which I powered with quality, if you had checked first you would of known this, but no matter, not really required for you to know who is who and all that jazz. I moved on to a much more refined speaker than the Amazing could ever hope to be.
Mega is ready to move on, he plainly explains what he hears, so why even bother, let it go.
RT1 -
If you like vandys Ben, you need to get an ear on the 5's.
I'm a big speaker kind of guy. My legacy's still make me smile and give me no reason to look around....or was that my wallet talking ? I dunno. The whispers hd,and Montana Kas or Was would be on my short list if the wallet ever resurfaces.HT SYSTEM-
lsi 9's -
stubby
SDA's are slow speakers when you're talking ESL's, Carver Ribbons and Maggie's. Overall SDA's are a slow speaker. That's one of my gripes with my 1C's.
Transient response is part of what Mega is talking about when he says 'fast', also control of whatever type transducer is producing the sound. IMO, as a general statement, the faster and faster the speaker system the farther it CAN sound from natural. Human voices and acoustic instruments are not always ultra fast in real life. But many box type and traditional cone speakers do a poor job of imitating reality. It's about capturing and then reproducing the complex harmonics in REAL music or human voice. The textures and nuances so to speak. That's why tubes rule and add soul.
As always, it comes down to synergy with the entire system. And tubes rule and tubes add SOUL!
I can't say the same.Political Correctness'.........defined
President of Club Polk -
reeltrouble1 wrote: »Mega is ready to move on, he plainly explains what he hears, so why even bother, let it go.
RT1
Thanks RT1! I think there is no one on this board who love Carver Plats more than I do. I just plainly madly love my Plats.
I love them so much so that I experiment quite a lot gears with them. The gears I put on my Plats far far far exceed anyone's expectations to power them with.
You are right about Ribbon Mass. It's the restraint for the ribbons to move faster. Then, there is the Xmax issue. Regardless of they can move fairly fast, the Xmax for the ribbon is limited. Also, the surface area is limited for such a wide bandwidth coverage. Then, there is attack and decay issue where all speakers must deal with. The Plats works absolutely fine and the only issue I realized so far is with a high pitch female voice and complex string instruments in the passage.
I am absolutely not nick picking whatsoever by what I said before. I love my plats like my first love.
So you are right and it's time for me to move on. I will put my plats on a Altair and bow to them everyday before I go to my future speakers for a listen.
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I loved mine as well. They have been present and a played speaker at no less than four Polkfests so they get their due here and if someone wants to claim it as there speaker for life no problem.
There is though a whole world of audio beyond Carver.
Like Holt said, there is no perfect speaker, gear, etc.. just things we enjoy. -
Agreed! There is no prefect anything....we just need to move on when the time comes...:)
The very nice thing about the Plats is that they'll reveal any change in gears and they'll truthfully tells you how the gear sounds and how good it can make the music. The plats panted for only this one time and I think I understand what it means.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
What is that, Kenwood amps?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I still don't have a frigging clue as to what you are saying.....I mean, I think I know what you are trying to say, I guess, I just don't agree with it.
mhardy6647 wrote: »:-) or maybe even rebadged Trios...
LOL...Mr. Ken change the chassis for the supreme and charge about 10 times more and I said hell yeah!.
BDT
Troy,
I know what you are saying but trust me I need a fastttttttttttt speaker. The ribbon in plats are at least 20 yrs old and the ribbon technology doesn't stand still. The weight (mass) due to the thickness of ribbon mass is a lot lesser these days.
I need a Fastttttttttttt speaker. I don't know if BG RD75 uses lighter line source ribbon or not but I suppose it's time to find out.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
The diaphragms in old (and new) compression drivers are pretty low mass... and the motors that drive them can be pretty beefy.
Have you listened to, say, an Altec 288? -
Don't take this the wrong way, but that's horsehockey.
Ribbon technology is physics and really hasn't changed all that much. The mass of those ribbons is insignifcant. I mean, if you want new speaks and the Carver's just aren't giving you wood like they used to, I get that. It happens. I'm also not discounting mechanical failures....but to say that the ribbon technology can't reproduce sounds as convincingly because of limitations inherent to the Kapton ribbons is manure.
