anyone know the ideal volume for a 12" DB-12 sub 4ohm?
Systems
Systems Posts: 14,872
edited January 2004 in Car Subwoofer Talk
ideal volume and workable range. thanks
yes i'm aware sealed enclosures only
Testing
Testing
Testing
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited January 2004
    The ideal enclosure for DB12's is .88 cubic foot. This INCLUDES the subwoofer displacement, which is to say, you make the enclosure to .88cft and dont worry about the sub.
    Yes you are completely correct.. these are sealed enclosure subs only, and will perform many times better if installed such. They do operate ported but you must underpower them and have the box ported perfectly to match your install AND the resonant freq of the subs themselves.. In short, after it is all done meticulously... you end up with less spl.. so sealed only.
    I once ran 2 db12's and pushed 127spl in my car with them in a free crappy ported box that has 2x 1.4cft volume.. using 150 watts a peice.. So if it is right, it will perform much better.. they are great subs, and hold up well.
    Happy Polking
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • Systems
    edited January 2004
    .88 cu.ft sounds about right from what i recall. any idea what the volume should be less the woofer -- meaning installing the sub inverted with the cone facing in and basket exposed?
    this is a great sub, i was running about 250w previously and it sounded awesome. i just have a new car and need to build a new enclosure.
    Testing
    Testing
    Testing
  • Systems
    edited January 2004
    250? try 350+... mucho gooder. boom boom bitty boom
    lets see what my driver displacement **** chart says...
    well now the DX 12 and DB 12 are just about the same structure size and all that jazz... pretty close in design and what not, but as far as size goes... i think you could put a DB in a DX's pair of jeans and no body woudl know the difference.
    that being said.. i've got displacement for the DX 12 listed at 0.062 cubic feet.
    so 0.88 minus 0.062 = 0.8138 cubic feet.
    that answer u're Q?
    Testing
    Testing
    Testing
