polk audio RM85 speaker stands
snavid972
i bought some speaker stands the other day but since the rm85/75 dont have holes in the back to mount they wont work they only have screws on bottom of the speakers and the stands dont have a screw hole to mount on the speak and dont know what i can do any suggestions, i bought the altantic speakers on amazon
Post edited by snavid972 on
I have the same speakers and I purchased these stands which work great:
OmniMount - GEMINI1
http://www.electronics-expo.com/make-a-store/item/OMNGEMINI1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20/OmniMount/GEMINI1/1.html
The speaker stands can be configured for 4 different type of speaker positions, the screw under the bottom of the speaker is one of the setup options.Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- RM 8 Center (center)
-- VM 10 (S.L/R)
-- DSW microPRO 1000 (LFE)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 6600 (L/R + center + S.L/R)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
I am planning on buying the same set. Thanks for the suggestions about the stand.
Blog Writing Service
