DD-WRT Question
polkatese
polkatese Posts: 6,767
edited October 2010 in Electronics
Polkies,
I have a quick question regarding DD-WRT: I have flashed two Linksys routers (WRT54GS and WRT54G2) and configured to be repeater bridge, one for the HT area (for firmware updates) and the other one upstairs. Both are secondary to a Linksys E3000 (main). Both appeared to be connected fine. But, I am not sure if it will cause problem eventually. How many DD-WRT repeater bridge routers can be configured to a Primary and active simultaneously?
TIA
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • dcmartinpc
    dcmartinpc Posts: 844
    edited October 2010
    The repeater bridge's should be looked at like wireless clients (Laptops, PC's, iPod, etc...) I like to keep my wireless devices below 10 or so... It tends to get congested after that, since true wireless bandwidth is only actually around 10 or 11 mbps...
    You should be just fine!
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • sir_lagzalot
    sir_lagzalot Posts: 258
    edited October 2010
    I have mine set to client bridge and they work fine. I have one in my bedroom and another in my sons bedroom, both are connected wirelessly to my main router downstairs.
    ****Home Theater****
    Integra DHC-40.1
    Rotel RMB-1075
    Fronts 265-RT
    Center 265-RT
    Rears 65-RT
    Sub BIC H-100
    ****VIDEO****
    Projector Epson 8700 UB
    BLU-RAY Sony BDP-S1000ES
    ****2-Channel****
    Magnepan SMGa
    Sub ED A3-250
    AMC 3100a
    TT Music Hall 2.2
    Bellari VP 130 Phono Pre
    Grant Fidelity Tube DAC-09
    Sirius Stiletto 2
  • polkatese
    edited October 2010
    Thanks guys...glad that I asked.
