Power supply capacitors
rubin
rubin Posts: 565
edited October 2010 in Electronics
Heat sinks heat up, thats their purpose. I've noticed the transformer and the power caps don't. So is that normal for a class a/b power amp.
Post edited by rubin on
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2010
    I don't think you should be sticking your fingers in there to see if they are hot ;)
    SOPA
  • rubin
    rubin Posts: 565
    edited October 2010
    Ricardo wrote: »
    I'm careful :) Even after several hours and the heat sinks are HOT, the toroidal transformer and the caps stay cool :confused:
  • Ricardo
    edited October 2010
    The transformer and capacitors are not supposed to get hot. The heat dissipated by the heat sinks come from the transistors (MOSFET's).
    SOPA
  • rubin
    rubin Posts: 565
    edited October 2010
    Ricardo wrote: »
    The transformer and capacitors are not supposed to get hot. I think the heat dissipated by the heat sinks come from the transistors (MOSFET's).
    Ok thanks for the reply.
  • cristo
    cristo Posts: 231
    edited October 2010
    Ricardo wrote: »
    If you have tube gear, be especially careful checking the warmth of the power supply capacitors,
    as they can carry a potentially lethal >400V wallop.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • rubin
    rubin Posts: 565
    edited October 2010
    cristo wrote: »
    these are ss amps, I know enough so as not to touch wiring of anything metalic .
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    reported
    Ben
