What kind of DB will I get off 2 12" new momo's
Systems
Exactly that I just bought 2 of the new 12" momo's and they want a 2 cubic foot box so I built one but havent hooked it up yet too my 2000W legacy amp you think they will pound at all. What kind of SPL? give me some guess's
Testing
Testing
Testing
Testing
Testing
that question has no answer
it all depends on the install, the car, amongst other things
2ft^3 it too big by about a 1/4ft^3
ideally they should be in separate chambers of .88
and a legacy amp is nothing to brag about
-Cody -
2kw legacy = 1k rms bridged @ 4 ohms = 500 x 2 at 2 ohms = 250 x 2 at 4 ohms...
so... my rough estimate is it is the right size amp about... and you should do maybe 120 - 125 with a basic bare bones install -- put 350 on each sub and a good install in a very small car or single cab truck and you might do 135 - 140....
i did over 140 with two polk dx 10's and an mtx 500D kicking out about 800 watts.The Artist formerly known as PoweredByDodge
