Boxes and MM2104's
Systems
Systems Posts: 14,872
edited January 2004 in Car Subwoofer Talk
I'm buying 2 MM2104's and planning on putting them in a Q-Logic box (2x0.75 ft^3). Since the recommended size for the MM2104's is .66 ft^3, what should I expect performance wise? Will the extra .09 cu. ft. hurt me?
They'll be wired in parallel and driven by an alpine MRD-M500 amp (bench tested to 591 wRMS into 2ohms).
Thanks,
Gary
Testing
Testing
Testing
