AR Turntable
AudioGenics
AR Turntable
Model XA
Price: $100.00
Condition: Needs restoration
shipping CONUS: TBD
Model XA
Price: $100.00
shipping CONUS: TBD
Post edited by AudioGenics on
Hi JVC,
Does this include a tone arm, cartridge, or the plexiglass dust cover?
Can you read the date of manufacter on the lable?
Do you have a picture?
Thank you. -
tone arm and brass counter weight is included
there is an Audio-Technica cartridge that is already mounted in the headshell.
it needs a replacement stylus.
It was already on the turntable.
the dust cover is cracked
I do not see a manufacturer date.
It may be internally stamped
I'll need to remove the cardboard bottom and check.
Maybe this weekend if I get motivated and also take some pictures.
There are two paper labels
In one of the corners a label that is glued states
AR Turntable
XA Model Serial Number 101836
address of the firm is also printed.
The other side
has a AR Guarantee Placard that is attached by staples
The bottom Post Card is not present. Already registered and sent in.
It does have a couple of hand written signatures. -
Since you noted that your XA needs restoration I thought I would pass along this info to help your buyer...
Belts for the AR Turntable are readily available on ebay.
A common problem that develops on the XA is that the tonearm wiring can fail after extensive use. If this happens they can be rewired with the great instructions found here:
http://www.vinylnirvana.com/ar_rewire.shtml
Best of luck with the sale.
