AR Turntable
AudioGenics
AudioGenics Posts: 2,567
edited October 2010 in For Sale (FS) Classifieds
AR Turntable
Model XA
Price: $100.00
Condition: Needs restoration
shipping CONUS: TBD
Post edited by AudioGenics on
  • Gempler
    Gempler Posts: 308
    edited October 2010
    Hi JVC,
    Does this include a tone arm, cartridge, or the plexiglass dust cover?
    Can you read the date of manufacter on the lable?
    Do you have a picture?
    Thank you.
  • AudioGenics
    edited October 2010
    tone arm and brass counter weight is included
    there is an Audio-Technica cartridge that is already mounted in the headshell.
    it needs a replacement stylus.
    It was already on the turntable.
    the dust cover is cracked
    I do not see a manufacturer date.
    It may be internally stamped
    I'll need to remove the cardboard bottom and check.
    Maybe this weekend if I get motivated and also take some pictures.
    There are two paper labels
    In one of the corners a label that is glued states
    AR Turntable
    XA Model Serial Number 101836
    address of the firm is also printed.
    The other side
    has a AR Guarantee Placard that is attached by staples
    The bottom Post Card is not present. Already registered and sent in.
    It does have a couple of hand written signatures.
  • Gempler
    Gempler Posts: 308
    edited October 2010
    Since you noted that your XA needs restoration I thought I would pass along this info to help your buyer...
    Belts for the AR Turntable are readily available on ebay.
    A common problem that develops on the XA is that the tonearm wiring can fail after extensive use. If this happens they can be rewired with the great instructions found here:
    http://www.vinylnirvana.com/ar_rewire.shtml
    Best of luck with the sale.
