Any Ideas or pictures of homemade center speaker stands for tv's
myke
myke Posts: 138
edited October 2010 in DIY, Mods & Tweaks
So I bought the CSi A6 and man it's BIG, ENORMOUS!! My problem is should I build a center speaker cover for the TV to sit on and stay on top of the entertainment center or should I put the center over the TV on a shelf (mostly hidden...quasi floating). Both will look somewhat ackward but I have to do something till we move and I end up mounting the TV and all my problems are solved. All advise is welcome.
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
  • TrashyTrucker
    TrashyTrucker Posts: 225
    edited October 2010
    Myke check this thread out and go down to post #11 thats where Im at except I need more space for amps. I dont want to rebuild and start over so I guess I might build on top of what I already have. Check it out.
    Matt
    http://www.polkaudio.com/forums/showthread.php?t=107929
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
    Toolfan66 Posts: 18,127
    edited October 2010
  • mole'
    mole' Posts: 3,160
    edited October 2010
    I built my own stand for my CSiA6.
    http://www.polkaudio.com/forums/showthread.php?t=77940
    looks like you did a good job on that stand.
    mole'
    edited October 2010
    Thanks!!
    I still have the stand but I moved everything out since those pics were taken.. Speakers have more space now!!
  • mole'
    mole' Posts: 3,160
    edited October 2010
    i need a BIGGER stand. i haz no more room
    mole'
  • myke
    myke Posts: 138
    edited October 2010
    Thanks for the comments everyone, I ended up buying these real low profile L braces/brackets.
    ________
    kinda look like that but cooler, made of steel, 11'"x8"x1", I sanded the powder coat and spray painted it with an oilbased paint that matches my walls, eventhough its behind the TV anyways, you cant even see the brackets since the center is right over the TV floating about 1/4'' over it at most. I didnt want to raise my TV above eye level when sitting. Drilled them into the studs so they can handle the CSi A6 weight (30lbs). I'll try to throw some pics up soon if nyone wants to see them, I know pics always help me.
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • myke
    myke Posts: 138
    edited October 2010
    my pic got messed up, imagine the /'s pushed over to the right like a brace for the upside L shape. BTW, they were only like $6 each and the srcews were $1.88 for 3 and I used 6, Spray paint was $4ish. Pretty cheap overall
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
