Benefits of Multi-Channel inputs......
shawn474
shawn474 Posts: 3,052
edited October 2010 in Electronics
Just a quick question. I have an Outlaw 950 pre that I have been using with my B&K AV5000 amp. I recently bought a B&K AVR-202 that has replaced the outlaw. When I was unhooking it, I noticed that the outlaw has the multi-channel imputs and realized that I have no idea what they are for. What is their purpose. I have the sony 1000ES that has the multi-channel outputs so was wondering, is this a better way to set-up your DVD or other components. If so, why? If not, why? Just looking to learn more about this feature. Thanks in advance.
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2010
    Using the multi-channel inputs let's your source do any decoding that happens. If the source (DVD/CD?) has better DACs, that's the way to go. It gives you options.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • shawn474
    edited October 2010
    Thanks, guys. So here is my question. I have a ps3 with no multi cahnnel and the sony 1000ES with multi channel. Would it be better to use the 1000es hooked up via multichannel to my pre? If I am reading correctly, that would then allow me to get the newest audio formats from the dvd player. Am i correct?
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    edited October 2010
    Thanks again, Rick. One last question........I have the B&K AVR with no multichannel. The outlaw 950 does. What do you think would sound better - the B&K without the multichannel or the outlaw with the multi channel to the dvd player? Do the new audio formats really make that much of a noticable difference? I really like the B&K, but if the outlaw is more "feature friendly" maybe I should relegate it to bedroom duty.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • nhhiep
    nhhiep Posts: 877
    edited October 2010
    the real question here is which device has a better decoder. you really have to test it yourself to find out. Sony ES should be very good
  • danger boy
    danger boy Posts: 15,722
    edited October 2010
    back in the olden days before fiber optic cables and digital coax cables.. to get multi channel 5.1 audio from your DVD player to your receiver.. we used multi channel inputs.
    six analog RCA cables were used.. things have changed. and most receivers/processors still have those inputs, but are not 7.1 mostly.
    The 6 inputs were also used later on for DVD-Audio and SACD multi channel audio formats.
    as some one said, now are mostly used for carrying the signal from a blu ray player to your receiver so you can hear the high def audio tracks. if you don't have HDMI
    PolkFest 2012, who's going>?
  • shawn474
    edited October 2010
    Thanks for all the replies.
    Yes, I have it connected to my television via HDMI for display purposes. It is connected via optical cable for sound. I guess I will try swapping out the B&K for the Outlaw and the PS3 for 1000es and see what it sounds like. It will be shootout; whichever set-up wins, I keep. Whichever doesn't oes to the bedroom or to my brother.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    edited October 2010
    OK, first off I want to thank mantis, Rick and everyone else for helping me out and answering my questions. Long story short, I ended up going back to the outlaw and relegating the ps3 to bedroom duty. Right now my HT consists of the Outlaw 950, B&K AV5000 amp, my samsung tv and the Sony BDP-1000es. I finally figured out what the multi-channel inputs are used for (thanks to the forum). I have the 1000es hooked up to the outlaw via multichannel and all I can say is WOW!!!! I popped in Avatar tonight after I got finished reconnecting everything and it was stunning.
    So now I have the B&K avr-202, RT55's, a cs400, and RT35's to go with the ps3 for my bedroom/secondary setup. Now all I need is a subwoofer!!!!!
    Thanks again all,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2010
    Congrats, enjoy.
  • shawn474
    edited October 2010
    One thing I have noticed is that in order to get multichannel sound from the dvd player, I have to push the 6 channel button on the outlaw remote every time I turn it on. I don't know if there is a way to save this setting as default so I don't have to do that everytime. If I choose not to use the bypass, it is connected through optical cables, but I do not get dolby digital / dts sound. The display says it is playing at PL-II, but the preamp is set to default to DTS/Dolby Digital. Anyone know if there is a way to fix this and the other issue?
    Thanks in advance,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
