rd0194 vs rd0198
silvertuner
silvertuner Posts: 496
edited September 2010 in DIY, Mods & Tweaks
obviously these are not "direct drop in upgrades" between eachother. simple question. is there a way to be able to put a rd0198 in place of a rd0194? if its as simple as modifying the crossover, this sort of work does not scare me. its finding the parts to do it. any advice and suggestions are welcome
some cheap free sony speakers
psw125
denon 1610
3.1 channel because i hate cables ran across the living room like that
Post edited by silvertuner on
    heiney9 Posts: 25,492
    In a word no, but there are a couple model's of SDA's that can be modified to use the 198 in place of the 194 fairly easily.
  • silvertuner
    wiring issues or fitment issues? im planning on rebuilding my crossovers for one set that i have so it doesnt really bother me to rewire it, again its finding the parts to make it work. unless polk has "crossover rebuild kits" for their speakers lol
    psw125
    denon 1610
    F1nut Posts: 51,954
    Perhaps if you stated exactly which speakers you have, we could provide better answers to your questions.
  • silvertuner
    rta8t's. it appears removing a resistor and adding a capacitor and a few other small tricks, it would work just fine with it. isnt the 198 what came with the 8tl? so basically just need to match the crossover from the 8t to the 8tl?
    psw125
    denon 1610
  • silvertuner
    lol i may just attempt and see what happens. any ideas on a site that would have the parts to upgrade the caps?
    psw125
    denon 1610
    Toolfan66 Posts: 18,164
    Funny thing I just gutted a set of those yesterday. I have the Drivers, Tweeters, and Crossovers boxed up. The cabinets are out by the trash..LOL
    Good Luck...
  • silvertuner
    which ones? the 8t or 8tl? if u have the tweeters for the 8t and are interested in selling them im sure we could arrange something. maybe the crossovers too lol
    psw125
    denon 1610
    They are the 8t PM sent
  • silvertuner
    sweet thanks man
    psw125
    denon 1610
