Polk 5 jr for rears
NeilGabriel
Anyone using Polk 5 jrs for rears in HT? Center? Not enough bass end?
thanks
thanks
Post edited by NeilGabriel on
What are you using for fronts? I think Monitor 5JR's would make fine surrounds for a vintage Polk HT. They have more bass than you would think.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
I have used a pair for my Rears, especially with Mon 10's as Fronts.
Definitely have more base than the Mon 30's I tried, for a while.....
(misconception that I needed 'newer speakers"...wrong..LOL) -
I am trying to put small system together for kids who have small apt (daughter and so-in-law). They have 5's for fronts right now and no rears..
This is a first system that cant be cranked...
thx -
With Monitor 5's for fronts, 5jr's would be fine for rears. They're pretty large for surround duty, but if the size is okay, then I say go for it.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Go for it. I have two sets of Monitor 5JR+ series II doing duty as side and rear surrounds in a 7.1 system. I think they have plenty of body to fill the space with surround sound that will make you flinch from time to time. I have mine mounted using tilt and swing LCD monitor brackets I bought from Monoprice for about $15! You can see pictures here:
http://picasaweb.google.com/aas.sanchez/LivingroomAudio?feat=directlinkPolk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
